Go to Post Now I'm having visions of thousands of balloons and a grumpy old man. Oh, and a talking dog. No talking dogs on the field. Grumpy old men are ok - sometimes. - JaneYoung [more]
Thread Tools Rating: Thread Rating: 20 votes, 5.00 average. Display Modes
Unread 16-02-2015, 16:50
Pramizle Pramizle is offline
FRC #3145
Pramizle is an unknown quantity at this point
PID Control of a Jaguar
We are trying to use a PID loop on our robot to set an elevator-like mechanism at a certain height. We are using an encoder to gain the feedback of where the elevator is sitting. Our primary build mentor has told us that their should be a way to set a maximum and minimum speed of the motor and then the PID loop will just control the acceleration/deceleration. However, we cannot find any place to do this. We have checked the WPI Library files and ReadTheDocs to no avail. If anybody has any experience with this that would be great.
Unread 16-02-2015, 17:36
Ethan_P Ethan_P is offline
FRC #1895 (Lambda Corps)
Team Role: Leadership
Rookie Year: 2013
Ethan_P is an unknown quantity at this point
Re: PID Control of a Jaguar
If your elevator is its own subsystem, instead of extending Subsystem, you can extend PIDSubsystem. In the constructor, call the PIDSubsystem constructor (super(double p, double i, double d); ), giving it the three coefficients. After that, you can create properties, if you want to change the defaults, such as (setOutputRange(-1.0.1.0); ), and (setAbsoluteTolerance(0.1); ). You want to read the java docs for all of the methods of PIDSubsystem. Last, you need to create methods (public void usePIDOutput(double value){}) and (public double returnPIDInput() {}) in the curly brackets of usePIDOutput assign you motor(s) the argument 'value', and in returnPIDInput, you would return an number, such as the encoder value.
Unread 16-02-2015, 18:14
gbear605's Avatar
gbear605 gbear605 is offline
Scarebear
FRC #1768 (Nashoba Robotics)
Rookie Year: 2014
gbear605 is an unknown quantity at this point
I'm assuming that you can do most of creating the PID loop, and only need help with the specific setting minimum and maximum speeds. If this is the case, you'll need to run the following method in the constructor of the Subsystem, where "pid" is the PID Controller.
Code:
pid.setOutputRange(minimumOutput, maximumOutput);
If you're using a PID Subsystem, you would just call setOutputRange in the constructor of the class.
