Go to Post Will.I.Am is not FIRST. - BrendanB [more]
Unread 16-02-2015, 17:58
BrighidKHeh's Avatar
BrighidKHeh BrighidKHeh is offline
FRC #3871 (Trojan Robotics)
Rookie Year: 2011
BrighidKHeh is an unknown quantity at this point
Exclamation No Code in Driver Station!
I run the code perfectly in Eclipse. There are no errors or warning in the code. When I run the code, the buildpath says "Remote command failed with exit status 1". The code still builds successfully even with this error. When I get to the Driver Station, I have no Robot Code. I receive the following error:
ERROR Unhandled exception instantiating robot org.usfirst.frc.team3871.robot.Robotjava.lang.Clas sNotFoundException: org.usfirst.frc.team3871.robot.Robot at [java.net.URL.ClassLoader$1.run(URLClassLoader.java :372), java.net.URL.ClassLoader$1.run(URLClassLoader.java :361), java.security.AccessController.doPriveleged(Native Method), java.net.URLClassLoader.findClass(URLClassLoader.j ava:360),java.lang.ClassLoader.loadClass(ClassLoad er.java:424), sun.misc.Launcher$AppClassLoader.loadClass(Launche r.java:308), java.lang.ClassLoader.loadClass(ClassLoader.java:3 57), java.lang.Class.forName0(NativeMethod), java.lang.forName(Class.java:259), edu.wpi.first.wpilibi.RobotBase.main(RobotBase.jav a:197)]
I have tried renaming the packages, I have tried scanning the code, and I even fixed an issue in the build path.
