Go to Post There are no simple solutions, as every solution has its own problems. - M. Lillis [more]
Unread 16-02-2015, 18:31
restouffer's Avatar
restouffer restouffer is offline
AKA: Bob Stouffer
FRC #2539 (Krypton Cougars)
Rookie Year: 2010
restouffer is an unknown quantity at this point
CAN Talon Does Not Move in Speed Mode
We have a CAN Talon SRX wired to an encoder. When in PercentVBus mode, the motor moves and we can see our encoder values changing. When changed to kSpeed mode, the motor does not move. We have checked the System Configuration webpage on the roboRIO, and have even run a Self-Test while this is running. The Self-Test shows an error and an applied throttle, but the motor does not move. We have tried values in the range of 20 to 200.
Here is a snapshot of one Self-Test:
We followed the code given in the Software Reference:
Code:
        elevatorMotor = new CANTalon(RobotMap::Elevator::elevatorMotorID);
	elevatorMotor->SetControlMode(CANSpeedController::kSpeed);
	elevatorMotor->SetSensorDirection(true);
	elevatorMotor->ConfigSoftPositionLimits(
		RobotMap::Elevator::maxPosition,
		RobotMap::Elevator::minPosition
	elevatorMotor->SetPID(
		RobotMap::Elevator::P,
		RobotMap::Elevator::I,
		RobotMap::Elevator::D
	elevatorMotor->SelectProfileSlot(0);
	elevatorMotor->SetIzone(300);
	elevatorMotor->SetCloseLoopRampRate(48);
	elevatorMotor->SetVoltageRampRate(0);
Code:
elevatorMotor->Set(speed);
Anyone have any thoughts?
Unread 16-02-2015, 18:45
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: CAN Talon Does Not Move in Speed Mode
Section 17.5 of the TALON SRX Software Reference Manual lists the throttle range as -1023 to +1023. A throttle of -19 is very, very small--less than 2%. You might need to increase the P value.
Note that the speed value is in encoder counts per 100 milliseconds. You will need to convert from RPM (or whatever speed units you use) based on the number of encoder counts per revolution. Note also that the encoder is always read in 4x mode, so a 250 cycle per revolution encoder is actually 1000 counts per revolution.
Unread 16-02-2015, 19:05
restouffer's Avatar
AKA: Bob Stouffer
Rookie Year: 2010
Thanks for the quick reply. We have increased the P value and will give it a try as soon as the fabrication team gets done with the robot.
Unread 16-02-2015, 19:56
restouffer's Avatar
AKA: Bob Stouffer
Rookie Year: 2010
Yep, that was our problem. I'm not used to working with numbers in the thousands, and we were a bit worried about setting the value too high. Now we know better.
Thanks for your time.
Unread 17-02-2015, 19:44
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
Glad you guys are up and running.
Just a guess : AppliedThrottle at -19 and ClosedLoopErr is -200, so I'm guessing Pgain was 0.1.
Unread 18-02-2015, 08:27
restouffer's Avatar
AKA: Bob Stouffer
Rookie Year: 2010
Good guess. Changing P to 1 and speed to 400 seems to work much better.
