Go to Post It would be wise to consider the reasoning behind the statement rather than the statement itself. Sometimes they are right... other times their statement is incomplete... and other times they really do have no clue what they are talking about. - dtengineering [more]
Unread 16-02-2015, 23:24
Dominick Ferone's Avatar
Dominick Ferone Dominick Ferone is offline
FRC #5030 (The Second Mouse)
Dominick Ferone is just really niceDominick Ferone is just really niceDominick Ferone is just really niceDominick Ferone is just really nice
How to wire LED's to a limit switch?
We are looking to wire LED's to light up when a limit switch is pressed. We were wondering how do we wire and put the program in labview? These are not addressable LED's.
2010-2013 Team 353 The POBots - Student, 2014-present Alumni.
2014- present Team 5030 The Second Mouse - Mentor and Founder.
Unread 16-02-2015, 23:27
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: How to wire LED's to a limit switch?
We were talking about doing something like that...but not using the computer to do it. Just build a "custom circuit" that gets power from the PDB and routes it through the switch, to the LED.
It's a pretty basic circuit, essentially the same as that which you use to turn on a light in a room.
Unread 16-02-2015, 23:52
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Rookie Year: 2007
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
The only thing I would add to MrForbes' post is, if you are using plain LEDs (and not an LED strip of some kind), you should add a resistor in series with the LED. This should be a decent guide. The picture in the above post is intended for an incandescent bulb. If it's an LED strip, it probably already has appropriate resistors built into it.
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 17-02-2015, 00:43
Sperkowsky's Avatar
Sperkowsky Sperkowsky is online now
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Team Role: Leadership
Rookie Year: 2014
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
What leds are you using.
Unread 17-02-2015, 03:07
Mr V's Avatar
Mr V Mr V is offline
FIRST Senior Mentor Washington
FRC #5588 (Reign)
Team Role: Coach
Mr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond repute
It all depends on exactly what you want to do.
If all you want to accomplish is turn on the led(s) the simplest and in my opinion the best way to do it would be as Mr Forbes said. The caveats are to add the appropriate resistor(s) if using individual led(s) and make sure that the switch you are using is rated for the current it will carry. If using the common 3 terminal limit switch you want to connect to the C and NO terminals if you want the led(s) to turn on when the switch is pressed. If you want them to be off when the switch is pressed use the C and NC terminals. You could also set it up to do both by connecting the power source to the C terminal, one color say red to the NC terminal and another color say green to the NO terminal. That way the red would be illuminated when the switched is not pressed and green when it is pressed.
Now if you want to, for example to stop your lift motor when it reaches the and turn on the led then you would want to wire it to the Roborio. For that you would connect the C and NO terminal to a signal and ground DIO terminal. You would then want to connect a Spike to a relay port on the RoboRio and the led(s) to the Spike.
All statements made on Chief Delphi by me are my own opinions and are not official FIRST rulings or opinions and should not be construed as such.
https://www.facebook.com/pages/Team-...77508782410839
Unread 17-02-2015, 09:36
MrForbes's Avatar
AKA: Jim
As mentioned by others, I neglected the dropping resistor in my response. Yes, I forgot...but the reason I forgot, is that you can buy many "LED"s these days in a nice package that include the dropping resistor, and are easy to mount in a panel or such. We have a couple of these on our robot to indicate things to the operator.
Sorry for the confusion....probably induced by lack of sleep....
Unread 17-02-2015, 09:55
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
If you're out of relay ports or want something smaller than a spike, you can operate custom circuits using something like this 5V relay module switched from DIO ports. Modules are also available with single, 4, 8, or 16 relays from a wide variety of vendors.
Unread 17-02-2015, 11:15
We are using these LED's https://www.sparkfun.com/products/12023
Our idea was to have the limit switch get pressed the the strip lights up. We were thinking of simply hard wiring it since we thought it was easier as it was meant for when totes hit it, not to stop anything moving.
