Go to Post Tinkerer math = engineer - MikeE [more]
Unread 18-02-2015, 06:04
yara92's Avatar
yara92 yara92 is offline
M.Fawdah Mechanical engineering
AKA: Mohamed
FRC #1946 (Mechka Monster)
Team Role: RoboCoach
yara92 will become famous soon enoughyara92 will become famous soon enough
Re: Thomas Compressor
I understand what you say, I have problem that we use the Thomas Compressor, 1/10 HP Model: 405ADC38/12 it is not working until it up 120 PSI about 70 psi stooping then after a while continue working.
So I don’t know where is the problem . I use the wiring PCM
TEAM 1946-Tamra
Unread 18-02-2015, 09:15
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Rookie Year: 2012
rich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond repute
That compressor is rated for 100 psi. It will likely not stop running until the thermal switch on the compressor stops it. And then, it will not restart until the thermal switch resets.
The Nason pressure switch trips around 115 psi, well above the rated pressure of the compressor. It should not pressurize the system to the "fully charged" 115 psi level.
I don't know whether it is allowed to adjust the Nason switch to trip at a lower psi.
Unread 18-02-2015, 11:06
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
If this is the old FRC compressor, it will run to 120 PSI, no problem. The pressure switch is sealed. It is somewhat adjustable, but it would no longer be First legal. Since the rules require a specific part number, you cannot order it with a lower set pressure. Lot of discussion about this last year.
If you don't know what you should hook up then you should read a data sheet
