Go to Post If FIRST is going to succeed in its goals, then we need to help it. - jcatt [more]
Unread 17-02-2015, 15:15
AnnaliseDonavan AnnaliseDonavan is offline
FRC #4284
AnnaliseDonavan is an unknown quantity at this point
Exclamation Robot Code Problem ** Again**
I run the code and the Driver station accepts it and allows it to run but when I press the buttons nothing happens? Pleas help ASAP
If I try to separate the Initializing of buttons from the button commands it fails to recolonize that they go together and created a whole mess of syntax errors
package org.usfirst.frc.team4284.robot;
import edu.wpi.first.wpilibj.Jaguar;
import edu.wpi.first.wpilibj.buttons.JoystickButton;
import edu.wpi.first.wpilibj.buttons.Button;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.livewindow.LiveWindow;
* The VM is configured to automatically run this class, and to call the
* functions corresponding to each mode, as described in the IterativeRobot
* documentation. If you change the name of this class or the package after
* creating this project, you must also update the manifest file in the resource
* directory.
RobotDrive Drive;
Joystick drivestick;
Joystick joystick;
int autoLoopCounter;
* This function is run when the robot is first started up and should be
* used for any initialization code.
public void robotInit() {
Jaguar FL = new Jaguar (5);
Jaguar BL = new Jaguar (2);
Jaguar FR = new Jaguar (3);
Jaguar BR = new Jaguar (4);
Drive = new RobotDrive(FL,BL,FR,BR);
drivestick = new Joystick(0);
joystick = new Joystick(1);
* This function is run once each time the robot enters autonomous mode
autoLoopCounter = 0;
* This function is called periodically during autonomous
/*if(autoLoopCounter < 100) //Check if we've completed 100 loops (approximately 2 seconds)
Drive.drive(-0.5, 0.0); // drive forwards half speed
autoLoopCounter++;
} else {
Drive.drive(0.0, 0.0); // stop robot
* This function is called once each time the robot enters tele-operated mode
public void teleopInit(){
* This function is called periodically during operator control
Drive.arcadeDrive(drivestick);
Button button1 = new JoystickButton(joystick, 1),
button2 = new JoystickButton(joystick, 2),
button3 = new JoystickButton(joystick, 3),
button4 = new JoystickButton(joystick, 4),
button5 = new JoystickButton(joystick, 5),
button6 = new JoystickButton(joystick, 6),
button7 = new JoystickButton(joystick, 7),
button8 = new JoystickButton(joystick, 8),
button9 = new JoystickButton(joystick, 9),
button10 = new JoystickButton(joystick, 10),
button11 = new JoystickButton(joystick , 11);
button1.whenPressed(new ElevatorOff());
button2.whenPressed(new ElevatorOn());
button3.whenPressed(new ElevatorReverse());
button4.whenPressed(new ArmsOut());
button5.whenPressed(new ArmsIn());
button6.whenPressed(new ArmsVerticalIn());
button7.whenPressed(new ArmsVarticalOut());
button8.whenPressed(new BlueLightShow());
button9.whenPressed(new LigthShowOn());
button10.whenPressed(new RedLightShow());
button11.whenPressed(new LightShowEnd());
* This function is called periodically during test mode
public void testPeriodic() {
LiveWindow.run();
import edu.wpi.first.wpilibj.Talon;
import edu.wpi.first.wpilibj.command.Command;
public class ArmsIn extends Command {
@Override
protected void initialize() {
// TODO Auto-generated method stub
@Override
protected void execute() {
Talon LeftArm = new Talon(9);
Talon RightArm = new Talon(8);
LeftArm.set(1);
RightArm.set(-1);
try {
Thread.sleep(500); //stop for 1/2 second
} catch(InterruptedException ex) { // allows for interruption of the sleep period
Thread.currentThread().interrupt();
LeftArm.set(0);
RightArm.set(0);
@Override
protected boolean isFinished() {
return false;
@Override
protected void end() {
@Override
protected void interrupted() {
public class ArmsOut extends Command {
@Override
@Override
Talon RightArm = new Talon(9);
Talon LeftArm = new Talon(8);
LeftArm.set(-1);
RightArm.set(1);
try {
LeftArm.set(0);
RightArm.set(0);
@Override
return false;
@Override
@Override
public class ArmsVarticalOut extends Command {
@Override
@Override
Talon In_Out = new Talon(7);
Talon In__Out = new Talon(0);
In_Out.set(-1);
In__Out.set(-1);
try {
In_Out.set(0);
In__Out.set(0);
@Override
return false;
@Override
@Override
public class ArmsVerticalIn extends Command {
@Override
@Override
Talon In_Out = new Talon (7);
In_Out.set(1);
In__Out.set(1);
try {
In_Out.set(0);
In__Out.set(0);
@Override
return false;
@Override
@Override
import edu.wpi.first.wpilibj.Relay;
public class BlueLightShow extends Command {
@Override
@Override
Relay relay1 = new Relay(0);
Relay relay2 = new Relay(1);
relay1.set(Relay.Value.kOn);
relay2.set(Relay.Value.kOff);
@Override
return false;
@Override
@Override
public class ElevatorOff extends Command {
@Override
@Override
Jaguar Elevator1 = new Jaguar(5);
Jaguar Elevator2 = new Jaguar(0);
Elevator1.set(0);
Elevator2.set(0);
@Override
return false;
@Override
@Override
public class ElevatorOn extends Command {
@Override
@Override
Elevator1.set(.25);
Elevator2.set(.25);
@Override
return false;
@Override
@Override
public class ElevatorReverse extends Command {
@Override
@Override
Elevator1.set(-.25);
Elevator2.set(-.25);
@Override
return false;
@Override
@Override
public class LightShowEnd extends Command {
@Override
@Override
relay1.set(Relay.Value.kOff);
@Override
return false;
@Override
@Override
public class LigthShowOn extends Command {
@Override
@Override
relay1.set(Relay.Value.kReverse);
relay2.set(Relay.Value.kOn);
try {
Thread.sleep(5000); //stop for 1/2 second
//Turn on lights Blue and Green)
relay2.set(Relay.Value.kReverse);
try {
// Turns on blue and red lights
relay2.set(Relay.Value.kForward);
try {
@Override
return false;
@Override
@Override
public class RedLightShow extends Command {
@Override
@Override
@Override
return false;
@Override
@Override
Please and thank you
Unread 17-02-2015, 15:24
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Re: Robot Code Problem ** Again**
Originally Posted by AnnaliseDonavan View Post
Code:
RobotDrive Drive;
Joystick joystick;
Declaring objects inside a method makes them local objects that (unless copied elsewhere) disappear when the method returns. I'm presuming you want these to be instance variables. In this case, declare them earlier and just assign them in robotInit():
Code:
RobotDrive Drive;
Joystick joystick;
Jaguar FL, BL, FR, BR;
P.S.: Also, enclosing your code with the tags makes it easier to read!
P.P.S.: After seeing this, I did not review the rest of the code.
Unread 17-02-2015, 15:36
BitBlt BitBlt is offline
BitBlt is an unknown quantity at this point
Are you sure your joysticks are setup correctly in the driverstation?
Can you drive the robot with what you expect to be the "drivestick"?
Put a breakpoint in the execute() function of one of your commands. Make sure you do a Debug As to deploy your project. Press the button of the command you have the breakpoint in. Does your breakpoint get hit?
As for your other question about declaring the buttons on separate lines, I saw in another thread that you were not giving a type to each declaration. So you need something like:
Button button1 = new JoystickButton(joystick, 1);
Button button2 = new JoystickButton(joystick, 2);
Button button3 = new JoystickButton(joystick, 3);
And so on.
You have a lot of local variables declared in each function. What happens when a Talon (for example) goes out of scope and is garbage collected?
Unread 17-02-2015, 15:55
Poseidon5817's Avatar
Poseidon5817 Poseidon5817 is offline
"Cool" Squad
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Rookie Year: 2014
Poseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud of
I noticed in your LightShowOn class you have thread.sleep(5000). You say in the comment that you are sleeping for half a second. Since it is measured in milliseconds shouldn't it be thread.sleep(500)?
My FRC History:
2014 - Team 1671: Central Valley Regional Finalist and Chairman's Award Winner, Sacramento Regional Finalist, Archimedes Quarterfinalist
2015 - Team 1671: Central Valley Regional Semifinalist, Sacramento Regional Semifinalist and Chairman's Award Winner, Newton Winner, Einstein Winner
2016 - Team 5817: Central Valley Regional Finalist and Rookie All-Star, Orange County Regional Quarterfinalist and Rookie All-Star, Newton Division
2017 - Team 5817: Return of the bench grinder
FRC #4284
When The ArmsVertical Talon is activated the Arms extend, Our robot has the option to extend and recall the arms.
as for the Arms in and out it goes inward in both directions to pick up/ let go of the bins/ garbage cans
Unread 17-02-2015, 15:56
FRC #4284
That accidentally got left on from the previous use of Thread.sleep
Unread 17-02-2015, 15:57
FRC #4284
Code:
RobotDrive Drive;
Joystick joystick;
The robot drive works, that is not the problem that I am running into I cannot get the buttons to work.
Unread 17-02-2015, 16:00
AWoL's Avatar
AWoL AWoL is offline
Lvl. 225 Dark Code Mage (Java Type)
AKA: Adam Wolnikowski
FRC #0225 (TechFire)
Rookie Year: 2014
AWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond reputeAWoL has a reputation beyond repute
Code:
First off, each of the buttons needs a type to specified. I personally do the declarations as all one line, and don't even name them. I would recommend you write them as such:
Code:
new JoystickButton(joystick, 0).whenPressed(new Command());
I'm not really sure whether or not this would cause compile errors, but I would definitely recommend using the OI class that even comes with the command based template to define the buttons, or at least do them in the Robot class constructor or as fields. Doing them in the periodic loop definitely isn't smart, as you want that loop to run as fast as possible, and creating 22 new objects every couple of milliseconds or so is a sure fire way to slow down the speed at which driver commands will be processed and to give the roboRIO memory issues. I'm also not sure if that is allowed, as I thought that joystick buttons are the same as DIO, PWM, etc. ports, in that you cannot allocate them multiple times.
As for anything beyond that, I'm sorry, but I didn't read it all. When posting code on chief, or anywhere else on the internet for that matter, always remember to format your code with code tags, which on chief look like this: [*CODE][*/CODE], except without the star. Another good rule of thumb is that people won't help you if you post more than 200 lines of code. So try and meet that, even if it takes some abstraction on your part.
2016 Competition Results (Co-captain, Driver, and Lead Programmer; Junior)
Springside-Chestnut Hill District Event - WINNER / #2 Seed, #1 Seed's First Pick / Gracious Professionalism Award
Westtown District Event - WINNER / #1 Seed / Industrial Design Award
MAR District Championship - WINNER / #1 Seed / Industrial Design Award / Dean's List Finalist Award (Me)
World Championship, Carson Subdivision - QUARTERFINALIST / #3 Seed, #2 Seed's First Pick
Indiana Robotics Invitational - FINALIST / #14 Seed, #2 Seed's Second Pick
Unread 17-02-2015, 16:07
Andrew Lobos Andrew Lobos is offline
FTC4977/FRC225 Alum
Rookie Year: 2011
Andrew Lobos is a jewel in the roughAndrew Lobos is a jewel in the roughAndrew Lobos is a jewel in the rough
Adam is right - you should only be creating the JoystickButton object once for each object and calling the method to bind to a command once (whenPressed, etc)
The command you specified will be automatically triggered as long as you are running the Scheduler every teleop loop
2012-2014: 225 Driver, Programmer & Co-Captain
2012-2014: FTC 4977 Driver, Programmer, & Team Captain
2011: 225 Operator & Programmer
2013: FRC: Springside-Chestnut Hill Winner (w/341 & 1495), Midknight Mayhem Winner (w/316, 369, & 869), Battle O' Baltimore Winner (w/1640, 2914 & 339), Duel on the Delaware Finalist (w/816 & 369), Ramp Riot Winner (w/341, 304, & 4637) FTC: PA State Finalist
2014: FRC: Springside-Chestnut Hill Winner (w/316 & 1495), Greater DC Winner (w/1731 & 4464), Midknight Mayhem Winner (w/25, 1626 & 329) FTC: PA State Champion
Unread 17-02-2015, 16:40
FRC #4284
Would this be a better way to set it up ? The template that I am using dose not have a OI
new JoystickButton(joystick, 1).whenPressed(new ElevatorOff());
new JoystickButton(joystick, 2).whenPressed(new ElevatorOn());
new JoystickButton(joystick, 3).whenPressed(new ElevatorReverse());
new JoystickButton(joystick, 4).whenPressed(new ArmsOut());
new JoystickButton(joystick, 5).whenPressed(new ArmsIn());
new JoystickButton(joystick, 6).whenPressed(new ArmsVerticalIn());
new JoystickButton(joystick, 7).whenPressed(new ArmsVarticalOut());
new JoystickButton(joystick, 8).whenPressed(new BlueLightShow());
new JoystickButton(joystick, 9).whenPressed(new LigthShowOn());
new JoystickButton(joystick, 10).whenPressed(new RedLightShow());
new JoystickButton(joystick, 11).whenPressed(new LightShowEnd());
Unread 17-02-2015, 16:56
FRC #4284
Unread 17-02-2015, 17:12
GBilletdeaux930's Avatar
GBilletdeaux930 GBilletdeaux930 is offline
AKA: Greg
FRC #0930 (Mukwonago Bears)
Team Role: Coach
Rookie Year: 2007
GBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to all
Another issue may be that you are declaring your buttons in teleopPeriodic. That will create these commands every 20ms. Instead declare them in your constructor or in teleopInit.
Unread 17-02-2015, 17:15
FRC #4284
When I remove them from that section it dose not put the two sets as connected and pulls up tons of syntax errors
Unread 18-02-2015, 15:50
AWoL's Avatar
Rookie Year: 2014
When you remove them where do you put them?
