Go to Post FIRST like life is what you make of it, if you would rather go through FIRST worrying about what other teams do to make their robots, then your destined for disappointment. if you go through FIRST making the most of it doing the best you and your team can then it doesn't matter what other teams do. - Mike Schroeder [more]
Unread 17-02-2015, 17:54
polarvortexrobo polarvortexrobo is offline
FRC #5637
polarvortexrobo is an unknown quantity at this point
14 awg wire on motors
Our CIM motors have 14 awg wire coming out.
Does that mean we're stuck with a max of 30A breakers?
or is there some weird exclusion here?
Unread 17-02-2015, 18:04
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Rookie Year: 2012
rich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond repute
Re: 14 awg wire on motors
There is a weird exclusion. See the text under the table in R38. Use a 40 amp breaker, and #12 wire.
Connect the #12 wire to the Motor Controller.
Connect the wire built into the CIM (regardless of wire gauge) to the motor controller.
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
The latter. There's a note under the table in R38.
Wires that are recommended by the device manufacturer or originally attached to legal devices are considered part of the device and by default legal.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 17-02-2015, 18:13
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
That's the rule. Here's a possible explanation.
Unread 17-02-2015, 18:25
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Rookie Year: 2012
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
Keep in mind that if you lengthen the motor wires you still need to use 12ga or larger. I'll be at Northstar but not as an inspector so I'm looking forward to checking out your robot!
Unread 17-02-2015, 18:52
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Internally to our team, we not only follow the gauges specified, but try to keep our runs down to 3 to 5 ft (1 - 1.5m). If we go much longer than that for motor wires, we'll bump to the next larger wire. We aren't as picky on signal-level, though we do a few checks to verify that the switches are reliably noted by the 'RIO. This year, we had originally planned to put our control panel at the highest level that our shortest control person could easily work on. However, for CoG reasons, we had put the battery and every motor as low as possible. The board came down.
