Go to Post I in all sincerity thoroughly enjoy the way that programming for FIRST makes me want to bash my head against a wall. - pogenwurst [more]
Unread 17-02-2015, 22:51
hwu24110 hwu24110 is offline
FRC #0988
hwu24110 is an unknown quantity at this point
Question regarding Victor Sp
So as we were finishing the robot and testing it out, we encountered an issue with the Victor 884s for our drive train. Two of them weren't working. I swapped the PWMs for them since we're using tank drive, and now only one works. (At competition, I may be swapping a bunch of PWMs as that had seemed to have worked in the past.)
To be prepared for our competition next month, we might purchase a Victor Sp to replace it, but would it be safe to have one Victor Sp connected to a Cim motor and a Victor 884 connected to another Cim motor, both motors attached to the same gearbox?
Unread 17-02-2015, 23:01
Sohaib's Avatar
Sohaib Sohaib is offline
AKA: Sohaib Nadeem
FRC #5036 (The Robo Devils)
Rookie Year: 2013
Sohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of lightSohaib is a glorious beacon of light
Re: Question regarding Victor Sp
If this was the Victor 888, I'd personally have to hesitation in doing so. But with the Victor 884s non-linearity, and the SPs linearity, I personally would not do it as both motors are mechanically connected, but not necessarily moving at the same speed with the same input.
You could do something fancy by artificially making your Victor SP non-linear through code, but that's a hassle.
2014 Season:
- Drive Coach
- Rookie All-Star Award (GTR-E)
2015 Season:
- Driver
- Deans List Semi-Finalist (GTR-E)
2016 Season:
- Driver
- Alliance Captain (GTR-E)
Unread 17-02-2015, 23:05
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
If they are connected to the same gearbox they will indeed be moving at the same speed. But they will not be sharing the load equally.
Unread 17-02-2015, 23:19
Sohaib's Avatar
AKA: Sohaib Nadeem
Rookie Year: 2013
Right, that's what I meant, thanks.
2014 Season:
- Drive Coach
2015 Season:
- Driver
2016 Season:
- Driver
Unread 17-02-2015, 23:03
Ether's Avatar
Rookie Year: 1969
Yes it would be safe, but it would not be ideal. The 884 has a much different response curve than the SP, so the motors would not be sharing the load equally and one might heat up more than the other.
Unread 17-02-2015, 23:08
FRC #0988
So I also assume it's not very recommended to have one side of the drivetrain to be powered by two Victor Sps and the other side powered by two Victor 884s?
Unread 17-02-2015, 23:14
Ether's Avatar
Rookie Year: 1969
That would probably annoy your drivers no end.
Unread 17-02-2015, 23:15
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
No, it's not.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Rookie Year: 2011
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Again, safe but not ideal. One side would have a different response curve than the other, resulting in one side moving at a different speed while you're applying partial power.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 18-02-2015, 01:22
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
This statement bothered me - what do you mean by "in the past"? If you mean "last month", OK. On the other hand, if you mean "last year", you do realize that the control system has been completely replaced this year, and last year's control system is no longer legal?
