Go to Post One day the code will be written first, and then a robot built around it - dag0620 [more]
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
  #16   Spotlight this post!
Unread 18-02-2015, 21:57
steelerborn's Avatar
steelerborn steelerborn is offline
Engineer at JBT FoodTech
AKA: Jonathan Stokes
FRC #5817 (Uni-Rex)
Rookie Year: 2007
steelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant future
Re: Ground Clearance Vex clamping gearbox
We only damaged the field in the very first practice match, after that we never hit the platform again and we played probably 17 matches.
But we were told that since our ground clearance was so low that we "could" damage the scoring zones so our frame would not pass inspection. I felt this was odd because you are flagging a robot for what "could" happen in the field, but if the intent was to damage the field I am sure teams could find a way and we would have many more robots not pass inspection.
For teams with low clearance just avoid the zones but probably start brainstorming options to raise your frame just in case.
Good enough is the enemy of anything great!
team 1671
  #17   Spotlight this post!
Unread 19-02-2015, 08:50
Chris is me's Avatar
AKA: Pinecone
I'd love to talk with the inspector that decides that robots must have a minimum ground clearance to compete. It is odd because it doesn't make any sense at all, and it's never been a rule that you have to have a specific ground clearance. If you don't damage the actual field, you're fine. That's my 2c.
  #18   Spotlight this post!
Unread 19-02-2015, 09:43
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
The edges of the scoring platform are taped. The gear could pull up the tape under the right circumstance. But no more than a stalled wheel spinning on the taped seam.
If you don't know what you should hook up then you should read a data sheet
