Go to Post Build a robot that isn't 119.999999 lbs - Peyton Yeung [more]
Unread 18-02-2015, 19:38
Potatoes's Avatar
Potatoes Potatoes is offline
AKA: Eric Wittmann
FRC #5136 (Mecha Pirates)
Rookie Year: 2014
Potatoes is an unknown quantity at this point
[5136] How we finished our bot for bag & tag
It was a stressful night but we made it just underweight by swiss-cheesing the frame and cutting our electronics board in half. Anyone else have trouble with robot weight? What did you do?
Unread 18-02-2015, 19:41
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
Rookie Year: 2011
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Re: [5136] How we finished our bot for bag & tag
Yell at the programmers and tell them to cut out anything that isn't 100% necessary.
Any post that I make expresses only my opinions. I do not represent the opinions of my team or of any entity affiliated with my team.
As a Mentor:
2016 - Engineering Inspiration at Greater Pittsburgh Regional
As a Driver:
2014 - Winner of Greater Pittsburgh Regional
Unread 18-02-2015, 19:48
Ben Wolsieffer Ben Wolsieffer is offline
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Rookie Year: 2011
Ben Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud of
We were at about 123 lbs on Monday night, but we managed to get it under by cutting a lot of holes.
We almost had to upgrade to a bigger compressor, which would have necessitated drastic weight loss measures, but we figured out a way to conserve air and make it work.
2016 North Shore District - Semifinalists and Excellence in Engineering Award
2015 Northeastern University District - Semifinalists and Creativity Award
2014 Granite State District - Semifinalists and Innovation in Control Award
2012 Boston Regional - Finalists
Unread 18-02-2015, 19:54
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Rookie Year: 2014
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
5137 here...we just got very lucky we were right under by 6 lbs could have easily been over like you. Hard to weigh as you build. Always want more that's the nature of building. We aimed for max weight ours last year was a tank right at 120.
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 18-02-2015, 21:03
xXhunter47Xx's Avatar
xXhunter47Xx xXhunter47Xx is offline
Lord of Lazy
AKA: Austin $wagmaster1337
FRC #4738 (Patribots)
Rookie Year: 2013
xXhunter47Xx will become famous soon enough
After weighing the chassis and then the elevator and having it be over 10 pounds, we went on a serious diet. Cut down towers, dropped two drive motors, swapped out 1/4" for 1/8" where possible.
Estimated to lose 10 pounds, lost over 20. Our only excuse is that someone weighed the robot with a battery in it.
College sux yo
Unread 18-02-2015, 21:09
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
Rookie Year: 2013
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Assuming you removed 2 Cims that would be 5 lbs right there. So I wouldn't be surprised about the number being over 20 lbs.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 19-02-2015, 00:15
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
No problem at all. We weighed in at 107.2 lb. We have a few bits we'll be swapping out, but we expect about 10 lb of our withholding allowance to be ballast, or possibly we'll be doing some marathon hacksawing in the pit!
Unread 19-02-2015, 00:22
MrForbes's Avatar
MrForbes MrForbes is online now
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We haven't been overweight since our rookie year. It's a common mistake, the weight sneaks up on you if you don't pay attention to it from the beginning.
As usual since then, this year we didn't get enough functionality to have to worry about weight. Even with two completely separate mechanisms to handle totes and containers.
Unread 19-02-2015, 09:27
Jpatterson1710's Avatar
Jpatterson1710 Jpatterson1710 is offline
AKA: Josh Patterson
FRC #1710 (Ravonics Revolution)
Rookie Year: 2012
Jpatterson1710 has a spectacular aura aboutJpatterson1710 has a spectacular aura aboutJpatterson1710 has a spectacular aura about
1710 had a stress free bag and tag, weighing in at team record low of 82lbs.
2012-2014 Mechanical Team FRC 1710
2014-2015 Chief Operations Officer FRC 1710
2016-Present FTAA
