Go to Post FIRST is the only high-school sport where everyone can become a pro - David Brinza [more]
Unread 18-02-2015, 19:41
youngpilot youngpilot is offline
AKA: Mary Luking
FRC #2640 (The Hotbotz)
Rookie Year: 2014
youngpilot is an unknown quantity at this point
Camera Issues
We're having problems with our camera- we have the vision set-up, but it does not display on the dashboard. I've looked through several threads on here, but I haven't been able to fix it still. There's screenshots of vision processing.vi and our dashboard project as well. Any suggestion as to what we should be doing to get it to work? We also configured it/got it working on the web.
https://flic.kr/p/qYhvdM
https://flic.kr/p/rfyTtV
Unread 18-02-2015, 20:04
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Camera Issues
From your code sample:
I assume you are using an Axis IP camera?
I also assume you have manually set the Axis camera IP to a static 10.26.40.11?
If these are correct guesses, then you do not need the Vision Processing code on the roboRIO. I would comment it out for now.
The Dashboard gets an IP camera image directly from the camera, so
delete or comment out the global "Camera IP" feeding into the "Camera Dashboard MJPG" vi.
Relace it with a hardcoded string: 10.26.40.11
Unread 19-02-2015, 08:15
AKA: Mary Luking
Rookie Year: 2014
Re: Camera Issues
Yes, we are using an AXIS Camera and have manual set it to that IP. Okay, we will fix that in the program today, and hopefully that will work! Thank you very much!
