Go to Post Each team is different, your mileage may vary. What works for your team does NOT necessarily mean it will work for others. - Andrew Schreiber [more]
Unread 19-02-2015, 15:01
Ninja3047 Ninja3047 is offline
FTC #4096
Ninja3047 is an unknown quantity at this point
[FTC]: [FTC]: Issues with the Hitechnic Superpro prototype board
Hi,
We're having some trouble with our Hitechnic Superpro prototype board, more specifically the read strobe. The read strobe seems to randomly stop working and then start working, but none of the code has changed, so I'm not sure what the problem is. We have confirmed it isn't an issue with the wiring because we used a Logic analyzer to directly read from the pin on the prototype board and received no readings. We also swapped prototype boards to confirm that it wasn't a defect with the board and got the same result. Any help would be appreciated.
Thanks,
FTC Team 4096 (T-[minus]10)
