Go to Post I can't wait until Kick Off! Simultaneously across the country there will be one loud cry of "Doh!", followed by the sound of smacking foreheads with the palm of a hand, then "Why didn't I figure that out? I saw the hint". Indeed, hind sight is 20/20. - billbo911 [more]
Unread 20-02-2015, 07:56
curtis0gj curtis0gj is offline
FRC #5033 (Beavertronics)
Rookie Year: 2015
curtis0gj will become famous soon enough
functions for auto
Hey guys I just finished my autonomous program on bag night and the next day realised how long and messy it was. So I got some help and made functions but I can't test them . So if anyone is able to help me here's the github link https://github.com/curtis0gj/5033-2014-15?files=1.
Unread 20-02-2015, 12:17
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
FRC #1684 (The Chimeras) (5460 Mentor)
Rookie Year: 2013
Arhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to behold
Re: functions for auto
FYI you can build them to search for syntax errors... like this
Code:
	private static void wait(Robot r, double waittime) {
		while (true) {
			if (!.risAutonomous() || !r.isEnabled()) return;
			r.Timer.delay(waittime); //r or just timer?
			return;
		private static void reset(Robot r) {
missing a } and i assume you mean ""!r.is..." not "!.ris..." (also, its just Timer.delay)
passing in Robot for everything is ugh-ly. just make Robot a singleton... or use a static initializer
Code:
			while (true) {
				double distance = r.encoder.get();
				double angle = r.gyro.getAngle();
				if (!r.isAutonomous() || !r.isEnabled()) return;
				r.robot.drive(-0.25, angle * r.Kp);
				//r.robot.drive(-0.40, 0);
				if (distance < -d) {
					reset(r);
					return;
the closed loop structure of this will hurt the robot, periodic ms timers are necessary
Code:
r.robot.drive(-.40, -1)
not Java-standard formatting
Code:
				Boolean maxarmlimit = r.limit4.get();
capital boolean (also that name scheme is bad, both on the variable and the limit)
Code:
					r.armmotor.set(Defines.ARM_SPEED);
					r.leftarmwheel.set(Relay.Value.kForward);
					r.rightarmwheel.set(Relay.Value.kReverse);
non-standard formatting (camelcase, descriptive names)
Code:
				if (angle > deg) {
comparing a double and an int
Code:
				r.robot.drive(-.40, -1);
constant loop? atleast a P loop, preferably PID
your "turn" and "turn2" functions are quite ineffective, basic angle averaging schemes should be used
other than that I'm losing my focus, but there are alot more issues
Unread 20-02-2015, 14:19
Rookie Year: 2015
Code:
		while (true) {
			return;
Code:
			while (true) {
					reset(r);
					return;
Code:
Code:
Code:
Code:
				if (angle > deg) {
Code:
Alright thanks I am going to make those changes.
Unread 20-02-2015, 17:32
Rookie Year: 2015
should distance be an int or a double and how should I add the periodic timer?
Unread 20-02-2015, 18:41
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Rookie Year: 2013
don't double post, use the edit button.
for distance, i usually go with doubles for most things so I don't accidentally mess data up with division.
don't know what the second thing you asked is in reference to. If it's the closed loop, than just do a Timer.delay(0.02) (20ms, standard 50hz operating cycle) inside the while(true) loop
Unread 20-02-2015, 18:53
Rookie Year: 2015
Alright I added in some delays inside the while(true) loop. I just put the delay as the first line in the loop I don't know if it matters.
https://github.com/curtis0gj/5033-20...ster/Auto.java
Unread 20-02-2015, 19:05
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Rookie Year: 2013
Preferably it would be the last line (with it at the first, theres a 20ms delay before any actions are performed)
Your indenting for everything after "wait" is now wrong
AUTOS should not be capitalized (and should be descriptive: "AutonMode", "SelectedAutonMode", "AutonEnum", etc)
turn and turn2 still need to be turned into feedback loops but for now rename them to turnLeft and turnRight and make one function- turn- that if gyro < desired than turnLeft(angle) else turnRight(angle)
capitalization schemes are wrong in Robot.java (http://java.about.com/od/javasyntax/...onventions.htm)
Code:
		if (autoMethod == Defines.AUTOS.AUTO_ONE) {
			return;
		} else if (autoMethod == Defines.AUTOS.AUTO_MOVE) {
			return;
		} else if (autoMethod == Defines.AUTOS.AUTO_TWORED) {
			return;
		} else if (autoMethod == Defines.AUTOS.AUTO_TWOBLUE) {
			return;
this block of code is rather... erm...
Why is your wait function inside of a while(true) loop?
Unread 20-02-2015, 19:55
Rookie Year: 2015
Code:
			return;
			return;
			return;
			return;
lol I did a very lousy job of naming things, sorry for that and I will change the names to be more descriptive and properly cased. Anyway how can I get the waits to work again? This is the function,
Code:
	public static void turn(Robot r, double deg) {
		while (true) {
			if(angle < 70) {
				turnRight(r, 70);
			} else {
				turnLeft(r, -70);
				reset(r);
				break;
I'm not sure how to program it, sorry I'm still fairly new to programming.
Unread 20-02-2015, 20:20
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Rookie Year: 2013
here's what I'd do
Code:
   if(deg < gyro.getAngle()){ //this is not right, need to have a function to handle rollovers
   //example for such a function: if Math.abs(deg-gyro.getAngle()) < 90 || Math.abs(deg-gyro.getAngle()) > 270
   //i dont know, just thinking to myself. see here for further instructions -> http://stackoverflow.com/questions/1878907/the-smallest-difference-between-2-angles
         turnLeft(r,deg);
   }else{
         turnRight(r,deg);
public static void turnRight(Robot r, double deg){
   while(true){
       //turn right
       if(distanceBetweenAngles(getGyro(),deg) <= MAX_ROTATE_ERROR){
           return; //or break; whatever
       Timer.delay(0.02);
except without the broken formatting since I made that in this text editor and not a code editor
E/ misunderstood the point of the code, fixed.
Unread 20-02-2015, 20:28
Rookie Year: 2015
here's what I'd do
Code:
         turnLeft(r,deg);
   }else{
         turnRight(r,deg);
So what will this whole function be used for calculating turns?
Unread 20-02-2015, 20:32
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Rookie Year: 2013
hm?
note that I edited that post like 5 times.
Anyway, heres a (maybe) working function
Code:
public static double angleError(double setpointDegressZeroToThreeSixty, double experimentalDegrees){
    double err = setpointDegressZeroToThreeSixty - experimentalDegrees; //0 360
    if(err < -180){
        err += 360;
    }else if(err > 180){
	err -= 360;
    return err;
double kp_rotate = 0.01;
double MAX_ERROR = 5;
public static void turn(double deg){
    while(true){
        double deltaAngle = angleError(deg, gyro.getAngle());
        if(Math.abs(deg-deltaAngle) < MAX_ERROR){
            break;
        }else{
            robot.drive(0, deltaAngle*kp_rotate); //drive taking a move and a rotate value
        Timer.delay(0.02);
