| Thread Tools |
Rating:
Display Modes |
.NET Framework 4.5 Issue
I am trying to install this so I can use the driver system, and this is the error message that comes up. Can anyone help me?
OS Version = 6.1.7601, SP = 1.0, Platform 2, Service Pack 1 OS Description = Windows 7 - x64 Home Premium Edition Service Pack 1 MSI = 5.0.7601.18637 Windows version = amd64_windowsfoundation_31bf3856ad364e35_6.1.7601. 17514_none_615fdfe2a739474c.manifest Windows servicing = 6.1.7601.17592 CommandLine = C:\c4cbd044004238cfc6b5139558\\Setup.exe /x86 /x64 /web TimeZone = Central Standard Time Initial LCID = 1033 Using Simultaneous Download and Install mechanism Operation: Installing Package Name = Microsoft .NET Framework 4.5 Setup Package Version = 4.5.50709 User Experience Data Collection Policy: Disabled Number of applicable items: 9 Exe (C:\c4cbd044004238cfc6b5139558\SetupUtility.exe) succeeded. Exe Log File: dd_SetupUtility.txt ServiceControl operation succeeded! ServiceControl operation succeeded! Exe (C:\c4cbd044004238cfc6b5139558\SetupUtility.exe) succeeded. Exe Log File: dd_SetupUtility.txt MSI (C:\c4cbd044004238cfc6b5139558\netfx_Full_x64.msi) Installation failed. Msi Log: Microsoft .NET Framework 4.5 Setup_20150220_152229737-MSI_netfx_Full_x64.msi.txt Final Result: Installation failed with error code: (0x80070643), "Fatal error during installation. " (Elapsed time: 0 00:01:19). |
Re: .NET Framework 4.5 Issue
What specifically are you trying to install? If you are trying to install an application that is also trying to install the .NET framework, you should try and install .NET separately.
You can download the .NET framework 4.5 from Microsoft here: http://www.microsoft.com/en-us/downl....aspx?id=30653 |
A quick Google of the error code found this Microsoft KnowledgeBase article:
http://support.microsoft.com/kb/976982 It appears that MSI is interfering with it. Hope this helps! |
Search "programs and features" in the start menu and click enter. Scroll down to Microsoft .NET Framework and see what versions you have installed. If you have an existing copy of 4 or 4.5, try uninstalling and re-installing it. Hopefully that works (or one of the other suggested fixes above). Otherwise, you might have a bigger issue at hand. |
So far none of these solutions have worked, even Microsoft's official "Fix It" tool hasn't fixed it, we have decided to try and reinstall Windows from the factory CDs (The kid's only had windows for 2 weeks and has only installed Minecraft and Chrome).
Give the offline installer a shot first:
.net 4.5: http://www.microsoft.com/en-us/downl....aspx?id=40779 or .net 4.5.2: http://www.microsoft.com/en-us/downl....aspx?id=42642 |
