Go to Post Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. - RoboChair [more]
Unread 20-02-2015, 19:19
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
FRC #1684 (The Chimeras) (5460 Mentor)
Rookie Year: 2013
Arhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to behold
Static IP from .2 to .20?
Background: The Windows mDNS responder is horridly slow and builds take nearly 40 seconds, 3 for the build and 37 to connect to the roboRIO 5 times. To fix this, I switched the order in build.xml from mDNS->USB->Static to Static->mDNS->USB and build times dropped to ~8 seconds.
However, recently, I tried to build and I couldn't get any static IP whatsoever, even though I had router and IP camera communications. I tried reflashing to no avail, only to notice that the reflasher tool said "Robot IP: 10.16.84.20"
When did it switch to .20? Now, SmartDashboard can't connect over static IP as well as the old build tools (half second fix for the build tools, using mDNS on the dashboard causes quite a bit of update rate lag)
Unread 20-02-2015, 19:41
weaversam8 weaversam8 is offline
Team Captain
AKA: Sam Weaver
FRC #4534 (Wired Wizards)
Team Role: Leadership
Rookie Year: 2014
weaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to behold
Re: Static IP from .2 to .20?
The DLink will begin assigning IP addresses starting at 10.XX.XX.20. You may be able to log into the online control panel for the roboRIO and force it to take a static address, but this might interfere with the Field Management System at events.
ORB Haow!
Unread 20-02-2015, 20:57
nickmcski nickmcski is offline
AKA: Nicholas McCurry
FRC #1482 (Grandin Ghosts)
Rookie Year: 2012
nickmcski has a spectacular aura aboutnickmcski has a spectacular aura aboutnickmcski has a spectacular aura about
This year the roboRIO dosent use a static IP, it uses a dynamic IP address, that means when the robot restarts the RIO can have a different IP. If you want it to have the same IP every time you have to either:
a) Set a mac reservation on the router
or
b) Set a static IP on the RoboRIO
That way the RoboRIO will always have the same IP.
Unread 20-02-2015, 21:39
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Windows doesn't come with an mDNS responder. It might be helpful for you to read through http://wpilib.screenstepslive.com/s/...rio-networking and identify what mDNS responder, what firewall, and how your network is configured.
My build times with mDNS and a large java project (86 classes) are 12 seconds.
Unread 20-02-2015, 22:27
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Rookie Year: 2013
According to that link,
Code:
NI mDNS Responder - Installed with the NI FRC Update Suite
This laptop is also a driver station so it uses the NI mDNS.
If it's worth anything, command line
Code:
ping roborio-1684.local
stalls for ~6 seconds before actually pinging >.<
firewall has been totally disabled for years now
Unread 21-02-2015, 07:20
Could you post the results of ifconfig and arp -a? I've never seen it take anywhere near that long if the device exists. You should see a ping response within a second.
Greg McKaskle
Unread 21-02-2015, 08:05
Chris Hibner's Avatar Unsung FIRST Hero
Chris Hibner Chris Hibner is offline
Eschewing Obfuscation Since 1990
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Rookie Year: 1997
Chris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond repute
Greg,
I have a question regarding mDNS and the LabVIEW dashboard.
We're trying to send some data from the dash to the robot over a UDP connection. In the past, we've done this using the robot's static IP address and have had no issues. This year, we've not had much success unless we use a workaroung which isn't going to work at competitions.
I'll apologize in advance for not being able to post code or look for minute details as I'm at home today and our team's computers are at the school.
Here is what we've done:
The main strategy is to use the part of the dashboard where it binds the smart dashboard to capture the IP address. In Loop 3 in the case structure where Bind Controls to Smart Dashboard.vi is located, we pull the robot IP address in the TRUE case and store it to a global variable. We use this global variable as the IP address in our UDP loop.
Here's the issue: the global variable that is supposed to contain the IP address comes back as an empty string around 80% of the time. We've been working around the issue by figuring out the IP address manually, but that won't work for competitions. Any suggestions?
An ounce of perception is worth a pound of obscure.
Unread 21-02-2015, 09:04
No need to apologize.
The dashboard relies on the DS to learn what the robot IP address is. It seemed like a good idea to not have the DB and DS looking at different robots. The notifier is necessary because the binding otherwise won't return. Storing the value in a local or global in the top loop or the third loop is a fine way to notify the rest of the DB of the robot IP.
So the way the IP sharing is supposed to work is for the robot IP and camera IP to be sent to the DB over TCP. The error handling for the DB TCP connection wasn't as good as it should have been, so I've seen some issues where the connection simply doesn't exist. The update last week corrected the known issues. PM me when you have access to the code, as I can tell you how to debug and improve it.
Greg McKaskle
Unread 21-02-2015, 11:57
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Rookie Year: 2013
Greg McKaskle
Note this is with no roboRIO (or any mDNS device attached for that matter) present, since our team only has one roboRIO currently in bag.
Code:
C:\Users\Arhowk>ifconfig
'ifconfig' is not recognized as an internal or external command,
operable program or batch file.
C:\Users\Arhowk>arp -a
Interface: 10.80.45.13 --- 0xc
  Internet Address      Physical Address      Type
  10.80.45.1            00-27-0d-7b-72-7f     dynamic
  10.80.45.255          ff-ff-ff-ff-ff-ff     static
  192.168.2.1           00-27-0d-7b-72-7f     dynamic
  224.0.0.2             01-00-5e-00-00-02     static
  224.0.0.22            01-00-5e-00-00-16     static
  224.0.0.251           01-00-5e-00-00-fb     static
  224.0.0.252           01-00-5e-00-00-fc     static
  224.0.0.253           01-00-5e-00-00-fd     static
  239.192.152.143       01-00-5e-40-98-8f     static
  239.255.255.250       01-00-5e-7f-ff-fa     static
  255.255.255.255       ff-ff-ff-ff-ff-ff     static
C:\Users\Arhowk>ipconfig /all
Windows IP Configuration
   Host Name . . . . . . . . . . . . : Arhowk
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
   DNS Suffix Search List. . . . . . : Lapeerschools.org
Wireless LAN adapter Wireless Network Connection:
   Connection-specific DNS Suffix  . : Lapeerschools.org
   Description . . . . . . . . . . . : Intel(R) Centrino(R) Wireless-N 100
   Physical Address. . . . . . . . . : 78-92-9C-8B-35-9A
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
   Link-local IPv6 Address . . . . . : fe80::2946:6c61:d614:24fe%12(Preferred)
   IPv4 Address. . . . . . . . . . . : 10.80.45.13(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : Saturday, February 21, 2015 11:50:24 AM
   Lease Expires . . . . . . . . . . : Sunday, February 22, 2015 11:50:24 AM
   Default Gateway . . . . . . . . . : 10.80.45.1
   DHCP Server . . . . . . . . . . . : 1.1.1.1
   DHCPv6 IAID . . . . . . . . . . . : 309891740
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-16-F3-49-42-C8-60-00-3A-9F-B2
   DNS Servers . . . . . . . . . . . : 10.16.6.201
                                       10.16.6.202
   NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection:
   Media State . . . . . . . . . . . : Media disconnected
   Description . . . . . . . . . . . : Atheros AR8151 PCI-E Gigabit Ethernet Con
troller (NDIS 6.20)
   Physical Address. . . . . . . . . : C8-60-00-3A-9F-B2
   DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter isatap.Lapeerschools.org:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter
   Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
Tunnel adapter isatap.{89EC4FD1-FB07-4BDB-981F-C8D057186120}:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Tunnel adapter Local Area Connection* 9:
   Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
C:\Users\Arhowk>
Unread 21-02-2015, 12:01
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
It looks like this is connecting through your school's WiFi, and the school uses the same 10. address range.
Any reason why you aren't connecting directly to the robot DLink SSID 1684?
Unread 21-02-2015, 12:03
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Rookie Year: 2013
As stated before, the robot is currently in the bag.
Won't be able to get data like that with the robot for a week or so.
If it's any help, our rookie team's driver station (x86 compared to my x64, Windows 8 compared to my windows 7, decently different laptops) also has the same hangtime.
Unread 21-02-2015, 12:47
Just Itinerant
Sorry, we have several DLink's left to test with after one got bagged with our robot.
Does your rookie team work in the same space as your team?
Is it a common WiFi environment or a common school system that might utilize similar AP setups?
It looks like you might be describing troubles only using the direct USB connection though.
Do you have the same issues with USB, Ethernet and wireless?
Unread 21-02-2015, 12:57
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Rookie Year: 2013
Yes
I don't understand what you're asking... though my next answer might help
Wireless works fine, normal ~200ms connection time to robot (ethernet ~100ms). USB has never worked for me, not since day 1, I've used exclusively Ethernet/wireless.
Rookie Year: 1997
ipconfig for windows. Invariably I use the wrong one.
  #15   Spotlight this post!
Unread 21-02-2015, 14:00
Oops. Yeah, I meant ipconfig, but auto-correct fixed it for me.
I was wondering if there were many interfaces up and whether the DNS server may be sent the .local name and be taking quite awhile to give up and revert to mDNS.
I think the thing I'd do is to disable the wifi and see if the USB timing changes. If that helps, you at least know why it takes so long. I'm not sure how to get the .local to go to mDNS immediately.
Greg McKaskle
