Go to Post you know the FIRST season is never over . . it just pauses a while so you can get some sleep. - Stuart [more]
Unread 20-02-2015, 19:19
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
FRC #1684 (The Chimeras) (5460 Mentor)
Rookie Year: 2013
Arhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to behold
Static IP from .2 to .20?
Background: The Windows mDNS responder is horridly slow and builds take nearly 40 seconds, 3 for the build and 37 to connect to the roboRIO 5 times. To fix this, I switched the order in build.xml from mDNS->USB->Static to Static->mDNS->USB and build times dropped to ~8 seconds.
However, recently, I tried to build and I couldn't get any static IP whatsoever, even though I had router and IP camera communications. I tried reflashing to no avail, only to notice that the reflasher tool said "Robot IP: 10.16.84.20"
When did it switch to .20? Now, SmartDashboard can't connect over static IP as well as the old build tools (half second fix for the build tools, using mDNS on the dashboard causes quite a bit of update rate lag)
