Aztechs 157 Build Season in 2 second clips
Here's a small video of our build season in 2 second clips each meeting.
https://www.youtube.com/watch?v=pvWh...ature=youtu.be |
Re: Aztechs 157 Build Season in 2 second clips
Nice! That robot looks pretty fly. I like how you've painted the 8020.
If you have the money, a 1/2" or 3/8" collet for your minimill would be useful. A whole set would be optimal. t will increase the rigidity fo your setups. What motors are driving the elevator? |
Looks like a great robot! I'm a big fan of the color scheme you guys have - it looks pretty professional. The rack and pinion grabber system is a neat solution too.
However, I really recommend that you don't ever use a drill chuck to hold an end mill as you're showing in the video. The drill chuck really isn't a collet or a tool holder, and isn't designed for side loads or gripping end mills. You'll get a poor surface finish, lots of chattering, reduced end mill life, and the risk of damaging the spindle, the chuck, or somebody. I know this the hard way. A student used a drill chuck with an end mill to spotface a hole, figuring an endmill could be used as a drill bit in a drill chuck. The jaws of the chuck were insufficient to hold the end mill, the bit caught the part and bits of metal went flying across the room. |
Nice!
