Go to Post Computers have a nasty habit of doing exactly what you tell them to do instead of what you want them to do. - KenWittlief [more]
Unread 22-02-2015, 17:41
BryceKarlins's Avatar
BryceKarlins BryceKarlins is offline
Video Production Junkie
FRC #1261 (RoboLions)
Team Role: Electrical
Rookie Year: 2010
BryceKarlins is on a distinguished road
24V Solenoids
So, during a post-build season rules read, and I realized that as per R18, the Motors & Actuators chart, that the rules don't allow solenoids that take over 12 volts!
Electrical solenoid actuators, no greater than 1 in. stroke and rated electrical input power no greater than 10 watts (W) continuous duty at 12 volts (VDC)
Not only have we been using 24V solenoids to no issue for a couple years now, theres a 24 volt jumper on the PCM!
Can someone tell me I'm suffering from pre-competition paranoia?
Unread 22-02-2015, 17:46
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
Rookie Year: 2013
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
Re: 24V Solenoids
yep just paranoia.
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Rookie Year: 2010
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Re: 24V Solenoids
The rule you quoted is talking about electric solenoid actuators, not pneumatic solenoid valves. 24V solenoid valves are still legal.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 22-02-2015, 17:48
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Rookie Year: 2012
Gregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond repute
Re: 24V Solenoids
Don't worry, 24V pneumatic solenoids are fine.
There's a distinction between an electric solenoid and a (pneumatic) solenoid valve.
R66 is what concerned solenoid valves.
Originally Posted by R66
C. Solenoid valves with a maximum 1/8 in. NPT port diameter,
D. Solenoid valves that are rated for a maximum working pressure that is less than 125 psi rating mandated above are
permitted, however if employed, an additional pressure relief valve must be added to the low pressure side of the main
regulator. The additional relief valve must be set to a lower pressure than the maximum pressure rating for the solenoid
valve,
This is where I'd remind you to switch the PCM jumper to 24V, but you already know about that it seems.
What are nationals? Sounds like a fun American party, can we Canadians come?
“For me, insanity is super sanity. The normal is psychotic. Normal means lack of imagination, lack of creativity.” -Jean Dubuffet
"Insanity is doing the same thing over and over again and expecting different results." -Albert Einstein
FLL 2011-2015 Glen Ames Robotics-Student, Mentor
FRC 2012-2013 Team 907-Scouting Lead, Strategy Lead, Human Player, Driver
FRC 2014-2015 Team 1310-Mechanical, Electrical, Drive Captain
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
