LED Strip Power
Hello! I'm doing some blingification with Adafruit Neopixels this year, and I'm trying to find out the best way to power them. Because FIRST locked down the other 5V 2A port from the VRM, I see a couple good options. There's the BEC converter from the old control system that powered the radio, of which we have PLENTY to spare. There's also a small UBEC I got for another project a while ago.
Does anyone else see other options? BTW: Neopixel strips need a relatively clean 5V, and anything over 6V will fry the whole strip instantly. Also, I'm using 4 meters, which should have a max current draw of ~8 amps (all LEDs on full white 100% brightness). I plan on using only 1/3 of that regularly, but don't what to fry anything if we accidentally use more than we expect. I guess I just want some thoughts and suggestions. Thanks! |
Re: LED Strip Power
We are using the same LED's and we are using the 12V-5V converter from the old control system connected to the PDP with a 20amp breaker. It outputs 5V-5amp's and the pixels will only use as much current as they need, but anything over 6V will fry the pixels.
Re: LED Strip Power
Yep. Also using a strip of NeoPixels with the old converter and it works a treat.
Re: LED Strip Power
We've used NeoPixels on our bots the last couple of years and found a couple of things that might be helpful to you. We used a the 5V/5A radio voltage regulator for powering the lights from last year and found that the dropout on those can be pretty high (we've measured >6V). On our bot last year, when the batteries were anything less than full, under load, the LED strip would display rainbow colors because the regulator couldn't keep 5V steady. This year, we tried a VRM (5V/2A) as suggested earlier and it was working great, especially since the buck/boost has a much lower drop out.
The Pololu solution was also one we were looking at, but we ended up going with some cheap UBECs from Amazon due to their low dropout and small size: http://www.amazon.com/NEEWER%C2%AE-U...s=5v%2F5a+ubec Another thing to mention is that make sure you include the resistor on the signal pin to the first LED. The signal line has some strange input characteristics and exhibits bad overshoot if you don't include the resistor to provide some simple filtering. We ended up frying the first LED in the strip that had already been taped inside of our arm and was an hour job to fix it. Here's an interesting article on it: http://www.eetimes.com/author.asp?do...&page_number=2 Last edited by VeqIR : 02-23-2015 at 04:43 PM. |
Re: LED Strip Power
Would throwing a couple of 5v regulators in parallel work for your application? Something like 4 LM323's on a perf board (with appropriate filtering) should be enough for your application.
Edit: See below and apparently don't do this. Also I may have a soon-to-be-crispy board floating around and should actually learn to EE. Last edited by wmarshall11 : 02-23-2015 at 10:16 AM. |
Re: LED Strip Power
Putting regulators in parallel is never a good idea unless you put enough resistance between each of the outputs to allow the variation in output voltage to go somewhere other than frying electronics. |
Re: LED Strip Power
The output isolating resistors will cause the output voltage to be lower than what you may want unless there is circuitry to compensate for them. |
Re: LED Strip Power
I second the 9A Pololu converter. This is a newer model than what we used last year, and handles over-voltage better. Make sure you add a decently beefy capacitor on the output. For the further paranoid, you can add a reverse biased zener diode to short power and ground when you go over voltage.
What you can do is independently power a subset of the strips. Last year we had 10 meters of WS2812 broken up into 5 strips, and used 3 separate regulators. You can see the cable bundle here: http://hackcasual.io/images/bling_installed.jpg |
