Go to Post Design is iterative, right? - JesseK [more]
Unread 23-02-2015, 15:05
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Old cRIO and Newest Labview 2014 (framework 2015)
This might have already been answered somewhere, but like most teams, I am sure you have 2-4 cRIO's laying around now. During the summer, it would be nice to use these older cRIO's for some robot projects. If we upgrade to Labview 2014 with (2015) frame work, that won't be possible anymore would it?
Is the best thing to do here is have an old laptop with FRC 2014 framework and keep it around so we can still deploy old cRIOs?
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 23-02-2015, 15:09
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Re: Old cRIO and Newest Labview 2014 (framework 2015)
The 2014 LabVIEW license is not supposed to expire and can target 4 and 8 slot cRIO's. The 2015 LabVIEW license can target 4-slot, but not 8-slot, cRIO's.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 23-02-2015, 15:21
Controls Engineer
AKA: chakorules
I think what we have or what I thought we got in the KOP this year was Labview 2014, but it's called "FRC 2015". So we are using Labview 2014. Does that sound right?
Favorite CD quote:
Unread 23-02-2015, 15:30
ebmonon36's Avatar
ebmonon36 ebmonon36 is offline
AKA: Eric Bredehoeft
FRC #1018 (Robodevils)
ebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud of
Send a message via AIM to ebmonon36
Yes. Labveiw 2014 (FRC 2015 season) can be used on the RoboRio and 4 slot.
Labview 2013 (FRC 2014 season) has a non-expiring license and can be used for the 4 and 8 slot cRIOs.
I am also keeping a Classmate laptop with the 2014 Driver Station image on it to run robots with 8 slot cRIOs.
Unread 10-03-2015, 13:56
apm4242 apm4242 is offline
FRC #4242
apm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud of
I just did this today. You can use the new Labview (FRC 2015 Season) and new 2015 Driver Station with the 4-slot cRIO but you have to reformat/re-image your cRIO first. Use the cRIO imaging tool in the Utilities tab on the LabVIEW start menu. Make sure to change the computer IP address to 10.xx.yy.6 (where xx yy are first 2 and last 2 digits of your robotics team number), change the subnet mask to 255.255.255.0, and disable the windows firewall.
You will need to re-deploy the code to the cRIO after you re-image it.
I also reconfigured my older wireless bridge using the 2015 configuration utility, but I'm not sure if that was necessary. Bridge Configuration Instructions.
