Go to Post Competition and inspiration go hand in hand. Those who inspire will be pushed to do it again and again by those who see this as a healthy competition. Those who are inspired will compete to be an inspiration to others. You can have your cake (competition) and eat it (inspire) too. - Andy Baker [more]
Unread 24-02-2015, 00:08
Optimism's Avatar
Optimism Optimism is offline
AKA: Calvin Ly
FRC #2468 (Team Appreciate)
Rookie Year: 2012
Optimism is an unknown quantity at this point
Team 2468 Appreciate Reveal: ORION
As per 148's request:
https://www.youtube.com/watch?v=g9bG...ature=youtu.be
Who Do You Appreciate?
Unread 24-02-2015, 00:15
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Re: Team 2468 Appreciate Reveal: ORION
That's a really good style reveal! Music and name perfectly matched it.
Neat looking robot too! What are you geared for for speed?
Unread 24-02-2015, 00:19
safiq10's Avatar
safiq10 safiq10 is offline
FRC #2950 (DEVASTATORS)
safiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond repute
Are you using the Andymark Swerve?
2014 Dallas Semi-Finalist (Thanks 3847 & 231)
2014 OKC Semi-Finalist (Thanks 2341 & 2461)
Unread 24-02-2015, 00:22
Optimism's Avatar
AKA: Calvin Ly
Rookie Year: 2012
We are using the AndyMark Swerve modules! They are noted to have a max speed of 11.5 ft/sec, but we are software-limiting it to half of that because the drive was too fast to meet the precision that we desired.
Unread 24-02-2015, 00:31
safiq10's Avatar
How was your experience with them?
Unread 24-02-2015, 00:42
LCJ's Avatar
LCJ LCJ is offline
AKA: Lewis Jones
Team Role: CAD
Rookie Year: 2013
LCJ is just really niceLCJ is just really niceLCJ is just really niceLCJ is just really niceLCJ is just really nice
We had no trouble integrating them into our design and they work great!
We had a little bit of a problem with the bevel gears but we got it fixed by taking it apart and putting in a spacer.
Quite hefty ... but that comes with any swerve drives.
Unread 24-02-2015, 00:43
bkahl's Avatar
bkahl bkahl is offline
Make Champs Great Again
AKA: Bailey Kahl
FRC #0125 (NUTRONS)
Rookie Year: 2013
bkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond repute
Can't comment for 2468, but 195 is also using the modules. For $325, I absolutely love them, but do recommend some minor changes after 6 weeks of testing.
1. Replace the bronze washer with a thrust bearing.
2. Shim the small bevel gear down to create a better mesh. We had a lot of chatter and skipping issues. This was solved very easily.
Both of these can easily be done with a quick McMaster order. For the overall price, with motors, I'm not complaining.
Team 125
College Student/Whatever Brando says
Team 195
Alumni
Facebook
EWCP
Unread 24-02-2015, 00:48
s1900ahon s1900ahon is offline
AKA: Scott McMahon
FRC #2468 (Appreciate)
s1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant future
One tweak we made was to widen one of the slots of the bevel gear shaft so that the key would fit into the slot and when the shaft collar was tightened it captures the motor shaft even better. JHersh proposed this update.
Unread 24-02-2015, 01:14
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
Maybe adding a switch could help like a coded gearshift. Just culling speed like that seems wasteful to me. Of course it's totally your choice, just something to consider.
Unread 24-02-2015, 11:14
AKA: Scott McMahon
Care to share P/Ns? A photo of the shims?
One thing we noted and were puzzled about was the inconsistency in the use of washers. Some modules used them with the spacers, some did not.
Unread 24-02-2015, 13:05
bkahl's Avatar
AKA: Bailey Kahl
FRC #0125 (NUTRONS)
Rookie Year: 2013
IIRC, I think they were .3mm 98089A293 and .5mm 98089A336.
Will post a picture tonight.
We noticed that the steering was much smoother with the extra washers as spacing too.
EDIT: We used the spring steel ones in .1mm and .3mm thicknesses. PNs are:
.1mm: 98055A111
.3mm: 98055A113
Team 125
Team 195
Alumni
Facebook
EWCP
Unread 24-02-2015, 13:58
barn34's Avatar
barn34 barn34 is offline
Isn't this how Skynet got started?
AKA: William Barnickel
FRC #2481 (Roboteers)
barn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond reputebarn34 has a reputation beyond repute
Awesome job, guys! Welcome to the swerve drive club. Hopefully, we'll get the chance to see each other again at champs. Best of luck on the season!
2016 Einstein Field WORLD CHAMPIONS & Carver Sub-Division Winner (330 & 120 & 1086)
2016 Smoky Mountains Regional Winner (3824 & 4740)
2016 Central Illinois Regional Winner (876 & 2220)
2015 Central Illinois Regional Winner (1756 & 2220)
2015 Rock City Regional Winner (2451 & 1625)
2014 Einstein Field Semi-Finalist & Galileo Division Winner (67 & 973 & 2363)
2014 Wisconsin Regional Winner (1732 & 2202)
--- Industrial Design Award (2010, 2015) ------ Innovation in Control Award (2013, 2014, 2016) ---
--- Quality Award (2015) ---------- Creativity Award (2014) ---------- Visualization Award (2009) ---
Unread 24-02-2015, 14:52
Unsung FIRST Hero
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Rookie Year: 2000
JVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond repute
All,
Looks like another very successful machine! I can't wait to get "the tour" later this week.
I hope your first swerve works out better for you than it did for us. though, with the same result.
-John
In the interest of full disclosure: I work for VEX Robotics a subsidiary of Innovation First International (IFI) Crown Supplier & Proud Supporter of FIRST
Unread 24-02-2015, 15:59
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
That was pretty good result, John. Unless I am recalling a different swerve? I think you mean 2008.
Richard Wallace
since 2003
  #15   Spotlight this post!
Unread 24-02-2015, 16:30
Coach Norm Coach Norm is offline
Team 2468 Coach/Adviser
AKA: Norman Morgan
Team Role: Teacher
Coach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond repute
All,
-John
I will be very interested to get some feedback from you regarding the elevator system.
If you are referring to 2008, I would be very happy with that result.
We are looking forward to returning to Dallas and competing.
FRC 2468 Team Lead 2008 - Present
Win The Day!
