Go to Post Remember. There is no controls team, no mechanical team, and no business team without The Team. - Tom Line [more]
Unread 24-02-2015, 00:39
GuyM142's Avatar
GuyM142 GuyM142 is offline
AKA: Guy
FRC #3339 (BumbleBee)
Rookie Year: 2012
GuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really nice
Robot drives forward with no joystick connected
I have noticed that when I'm not connecting the driver's joystick to the laptop the rocky just drives forward when enabled.
It's pretty dangerous and happens frequently because we use 2 laptops ac don't always move the joystick between them.
What can be done?
2016-2017 - Programming Mentor
Curie Sub-Division Champions with 694, 379 & 1511
2015 - Team Captain & Head of Programming Crew
Carson Sub-Division Champions with 1325, 20 & 1711
First ever Israeli team on Einstein
2014 - Team Captain & Head of Programming Crew
2013 - Head of Programming Crew
2012 - Member of Programming Crew
Unread 24-02-2015, 02:39
Levansic's Avatar
Levansic Levansic is offline
AKA: Len Evansic
FRC #0585 (Cyber Penguins)
Levansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud of
Re: Robot drives forward with no joystick connected
What is your drive setup? Are you directly feeding the joystick data into a drive VI like arcade or holonomic (mechanum)?
Does this happen all of the time, or just some of the time?
We have had this in the past, if someone was displacing the joystick while plugging it in, like pulling it slightly backwards. This happens when someone is holding the joystick as another person plugs it in to the USB port. Windows takes the initial position when plugged in as the default zero, so when the stick is released to its natural zero point, the computer thinks it is being pushed off of zero.
Unread 24-02-2015, 04:48
GuyM142's Avatar
AKA: Guy
Rookie Year: 2012
We just use the x and y axes for holonomic drive.
The weird thing is that it happens only for driving and only forward (y axis).
Happens every time the joystick is not plugged in.
Unread 24-02-2015, 07:00
If you request a joystick value, and the joystick isn't plugged in, the VI returns empty arrays. If you then index those empty arrays, LV will return the default value for that array type -- numbers will be zero, Booleans false, etc.
We were sort seeing the same thing earlier in the season with the POVs. The array was empty, but they were indexed anyway. The index returns a zero, which meant up on the elevator.
So, does any of this explain why this was happening? If not, can you post the code or a picture of the code that reads the joysticks and sends values to drive?
Greg McKaskle
Unread 24-02-2015, 07:34
GuyM142's Avatar
AKA: Guy
Rookie Year: 2012
Greg McKaskle
That's it!
We use the POV to make the mecanum go straight in any direction.
Is there a solution for this?
Unread 24-02-2015, 07:46
We added code to check the array size of the POV before blindly indexing it.
The attached image returns a -1 instead of a zero. This still may not be what you want, but it shows how to detect an empty array and control the downstream value. You can also put your code into a case structure and only execute it if the array size is not zero.
Greg McKaskle
Name:	From Clipboard.PNG
