Go to Post Now really, who would want to try and go against Andy Baker? That's like trying to single-handedly outscore 25, 254, and your choice of triplet with a shopping cart. - Billfred [more]
Unread 24-02-2015, 16:30
ninetypercent ninetypercent is offline
FRC #1124
ninetypercent is an unknown quantity at this point
Error 44036 PWM Not Allocated
Hi, I'm one of the coders of team 1124. I was having some problems opening talons. In begin, I use an open two motor vi but only one of the motors actually initializes while the other keeps on blinking. I'm not sure if it's a code problem or a mechanical problem, but the head coder tells me it's mechanical/electrical while the president tells me the electrical is fine. Is anyone else experiencing this issue, and how can I fix it?
Unread 24-02-2015, 16:37
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Error 44036 PWM Not Allocated
Verify that the Talon has a unique CAN ID (via WebDash) and that the ID is only referenced once in Begin.
Unread 24-02-2015, 16:38
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
If you are seeing "Error 44036 PWM Not Allocated" in the DS then it's likely software. Are you using Talon SR or Talon SRX (CANBus or PWM)?
I assume PWM but I think the DS error for CAN in Labview might also say "...PWM not allocated..." so I wanted to check.
Double check how you are motor-open-ing in Begin. Are the string refs right everywhere?
Unread 24-02-2015, 16:48
FRC #1124
I'm using 2 Talon SRs. One of them initializes while the other does not, but I use an open two motor vi for both of their PWM channels. And I double checked and I did make a mistake with one of the refnum names, but that doesn't explain why only one motor initialized out of the two motors. One talon continues blinking even when I enable the bot, while the other goes solid.
Unread 24-02-2015, 18:05
Just Itinerant
A simple sanity test is to swap the PWM cable ends between the two Talons SRs to see if the working Talon follows the roboRIO PWM output.
Then swap the roboRIO ends of the cables.
Unread 24-02-2015, 20:42
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
The error message is pretty specific. It strongly suggests that you are trying to use the same PWM channel for two different things. If you attach your code here, we can probably find the problem.
