Go to Post I can't believe that I said the CD community could be patient - in December. - JaneYoung [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 24-02-2015, 19:50
Aero Aero is offline
consumes pizza, produces code
AKA: Ari Lotter
FRC #0865 (Warp7)
Rookie Year: 2013
Aero is on a distinguished road
Can't get current from PDP, crashes.
Hey guys, I'm experiencing a lil bit of trouble with the PDP's CAN stuff.
I'm trying to make our compressor disable once we're drawing a certain amount of amperage, just cause that current allowance could be better used.
For some reason, calling the PDP's getTotalCurrent method is causing our robot to crash with a "CTRE CAN Recieve Timeout"
Here's the code and full error:
Code:
from wpilib import Compressor, PowerDistributionPanel
class Pneumatics(object):
	AMPERAGE_THRESHOLD = 20
	def __init__(self):
		self.comp = Compressor()
		self.pdp = PowerDistributionPanel()
	def update(self):
		Monitors the PDP for amp draw, and disables the compressor if amp draw is above a threshold to prevent brownouts.
		:return:
		if self.pdp.getTotalCurrent() > self.AMPERAGE_THRESHOLD:
			self.comp.stop()
		else:
			self.comp.start()
Code:
ERROR Unhandled exception:
Traceback (most recent call last):
  File "/home/lvuser/py/robot.py", line 110, in <module>
    run(Drake)
  File "/usr/local/lib/python3.4/site-packages/wpilib/_impl/main.py", line 100, in run
    retval = options.cmdobj.run(options, robot_class, **kwargs)
  File "/usr/local/lib/python3.4/site-packages/hal/main.py", line 11, in run
    return robot_class.main(robot_class)
  File "/usr/local/lib/python3.4/site-packages/wpilib/robotbase.py", line 185, in main
    robot.startCompetition()
  File "/usr/local/lib/python3.4/site-packages/wpilib/samplerobot.py", line 162, in startCompetition
    self.operatorControl()
  File "/home/lvuser/py/robot.py", line 95, in operatorControl
    self.update()
  File "/home/lvuser/py/robot.py", line 102, in update
    component.update()
  File "/home/lvuser/py/components/pneumatics.py", line 16, in update
  File "/usr/local/lib/python3.4/site-packages/wpilib/powerdistributionpanel.py", line 56, in getTotalCurrent
    return hal.getPDPTotalCurrent()
  File "/usr/local/lib/python3.4/site-packages/hal/functions.py", line 40, in outer
    raise HALError(getHALErrorMessage(status.value))
hal.exceptions.HALError: CTRE CAN Recieve Timeout
Unread 24-02-2015, 20:58
chsahit's Avatar
chsahit chsahit is offline
Lead Developer
AKA: Sahit C
FRC #0011 (MORT)
Rookie Year: 2013
chsahit will become famous soon enoughchsahit will become famous soon enough
Re: Can't get current from PDP, crashes.
HAL means hardware abstraction layer. In my experience, if you see this there is probably a probably a mechanical/electrical issue. Not a problem with the code. Do you see the compressor as a node on the RoboRIO's web interface?
Unread 24-02-2015, 21:11
AKA: Ari Lotter
FRC #0865 (Warp7)
Rookie Year: 2013
Yeah, should have mentioned; I can see the PDP fine in the RoboRIO's web interface. It has CAN ID 0, and it passes the self-test fine. It's weird, because the HAL is throwing the error, it's nowhere in RobotPy's WPIlib implementation.
Unread 24-02-2015, 21:35
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
EDIT : oops left editor open for too long....
That error occurs when you are trying to get signals from a CAN device you haven't received updates from. If possible you should catch that exception so it doesn't crash your app. Not sure how to do that in Py tho. Maybe someone else can recommend?
Is the PDP device ID the correct value, specified under "PDP CAN ID".
http://wpilib.screenstepslive.com/s/...ribution-panel
Does the PDP show up in the web-based config?
Unread 25-02-2015, 10:36
Cel Skeggs Cel Skeggs is offline
Robot Software Manager Alumnus
AKA: Previously known as Colby
FRC #1540 (The Flaming Chickens)
Cel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of light
Under Java (and probably C++), there's a distinction in the HAL between errors and warnings. In this case, this is a warning, and the Java WPILib would generally just log a warning instead of throwing an exception. Though, in reality, the Java implementation ignores all errors and warnings from the HAL about the PDP, possibly for this exact reason:
Code:
	 * Query the current of a single channel of the PDP
	 * @return The current of one of the PDP channels (channels 0-15) in Amperes
	public double getCurrent(int channel) {
		ByteBuffer status = ByteBuffer.allocateDirect(4);
		status.order(ByteOrder.LITTLE_ENDIAN);
		double current = PDPJNI.getPDPChannelCurrent((byte)channel, status.asIntBuffer());
		checkPDPChannel(channel);
		return current;
For those of you not well versed in the WPILibJ source, there is a conspicuous lack of a HALUtil status check:
Code:
HALUtil.checkStatus(status.asIntBuffer());
Without this check, warnings and errors from the PDP part of the HAL are not checked.
This may be a bug in the python implementation: it likely should log these as warnings, or ignore them altogether.
We ran into the same problem in Java with our custom wrappers (that would log warnings properly, even for PDP accesses) - randomly, the PDP would have chunks of time where it reported this warning on every access. Most of the time, it would work just fine. An example of this from our logs: (the time at the left is in milliseconds from startup)
Code:
[238266 WARNING] (Common.java:68) HAL Warning: CTRE CAN Recieve Timeout[1] in ccre.igneous.direct.DirectPDP.getCurrent(DirectPDP.java:42)
[238283 WARNING] (Common.java:68) HAL Warning: CTRE CAN Recieve Timeout[1] in ccre.igneous.direct.DirectPDP.getCurrent(DirectPDP.java:42)
[238285 WARNING] (Common.java:68) HAL Warning: CTRE CAN Recieve Timeout[1] in ccre.igneous.direct.DirectPDP.getCurrent(DirectPDP.java:42)
[238289 WARNING] (Common.java:68) HAL Warning: CTRE CAN Recieve Timeout[1] in ccre.igneous.direct.DirectPDP.getCurrent(DirectPDP.java:42)
[238304 WARNING] (Common.java:68) HAL Warning: CTRE CAN Recieve Timeout[1] in ccre.igneous.direct.DirectPDP.getCurrent(DirectPDP.java:42)
[238306 WARNING] (Common.java:68) HAL Warning: CTRE CAN Recieve Timeout[1] in ccre.igneous.direct.DirectPDP.getCurrent(DirectPDP.java:42)
[238311 WARNING] (Common.java:68) HAL Warning: CTRE CAN Recieve Timeout[1] in ccre.igneous.direct.DirectPDP.getCurrent(DirectPDP.java:42)
Software manager alumnus. Developer of the CCRE, a powerful robot code framework based on dataflow and composibility.
Refer to as she/her/hers. Years of FRC: 2012, 2013, 2014, 2015, 2016. FLL for a few years beforehand.
Team 1540: The Flaming Chickens | Portland, Oregon | Twitter | Facebook
Unread 25-02-2015, 11:00
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
FRC #1418 (), FRC #1973, FRC #4796, FRC #6367 ()
virtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant future
This does appear to be a RobotPy HAL bug, as Colby points out. I've filed a bug to track this at https://github.com/robotpy/robotpy-wpilib/issues/143.
Aero, if you could subscribe to that bug, I'll be pushing a possible fix for it in a few minutes. I won't be able to test it -- but presumably you can
Maintainer of RobotPy - Python for FRC
Creator of pyfrc (Robot Simulator + utilities for Python) and pynetworktables/pynetworktables2js (NetworkTables for Python & Javascript)
2017 Season: Teams #1973, #4796, #6369
Team #1418 (remote mentor): Newton Quarterfinalists, 2016 Chesapeake District Champion, 2x Innovation in Control award, 2x district event winner
Team #1418: 2015 DC Regional Innovation In Control Award, #2 seed; 2014 VA Industrial Design Award; 2014 Finalists in DC & VA
Team #2423: 2012 & 2013 Boston Regional Innovation in Control Award
Resources: FIRSTWiki (relaunched!) | My Software Stuff
Unread 25-02-2015, 11:08
virtuald's Avatar
RobotPy Guy
Also, it should be noted that the python library has two pieces (well.. three), one is a WPILib piece, and the other is a HAL piece. The HAL piece is just an abstraction, with two concrete implementations -- one for simulation, one for the actual roboRIO C++ hal wrapper.
It works pretty well, because we can run the same WPILib code for simulation/testing and on the real robot, unlike how the simulation stuff is implemented for Java. Hopefully they'll use our model next year.
Unread 25-02-2015, 11:19
virtuald's Avatar
RobotPy Guy
Fix posted at https://github.com/robotpy/robotpy-wpilib/pull/144, Aero please try it out and leave a comment to let me know if it works for you.
Unread 25-02-2015, 17:48
virtuald's Avatar
RobotPy Guy
RobotPy 2015.0.14 has been released and should address this issue.
