Go to Post Funny, I came to robotics for the robot, but find I stay for the people. - Mr. Pockets [more]
Thread Tools Rating: Thread Rating: 5 votes, 4.40 average. Display Modes
Unread 26-02-2015, 00:57
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
FRC #1296 (Full Metal Jackets)
wireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond repute
Send a message via AIM to wireties
Re: Quotes from the Chief Engineer and I
Originally Posted by Ether View Post
Unless you're trying to write efficient linear algebra algorithms. Then you better know whether your language is row major or column major.
The OP was talking of basic concepts, not efficient linear algebra algorithms.
Fast, cheap or working - pick any two!
Unread 26-02-2015, 12:14
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Understood. My post was mostly for the benefit of other readers, particularly high school students, who may have been left with the impression that row-major vs column-major storage never makes a difference.
Unread 26-02-2015, 12:25
techhelpbb's Avatar
techhelpbb techhelpbb is offline
FRC #0011 (MORT - Team 11)
Rookie Year: 1997
techhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond repute
http://zone.ni.com/reference/en-XX/h...sing_matrices/
Matrices a la LabView.
http://www.mathworks.com/help/matlab...nd-arrays.html
Matrices a la MatLab.
Sometimes arguing about the visual representation of data is basically a course in UI and graphics arts.
You can spend literally your entire life arguing which view is the best one. Like any communications - the 'right' one is that one that manages to deliver the right messsage as fast as possible to the audience to which it was intended.
Unread 26-02-2015, 12:33
Ether's Avatar
Rookie Year: 1969
Since your post is linked to mine I'll assume that was the intended context, since no other context was given.
I'll try to be clearer:
My post had nothing to do with "arguing which view is the best one". It was simply pointing out that there are domains in which a knowledge of how your programming language stores matrix elements is important.
Unread 26-02-2015, 12:43
techhelpbb's Avatar
Rookie Year: 1997
It's no problem, I did not intend for my post to be linked to yours at all.
I intended to address the topic in general.
However to go back to your point, if you consider the computers 'view' of the data you are absolutely correct.
Just as it wouldn't make sense to fight little-endian / big-endian it doesn't make any sense to fight the way your language works.
http://en.wikipedia.org/wiki/Endianness
Danny Cohen's "On Holy Wars and a Plea for Peace" published in 1980[7] ends with: "Swift's point is that the difference between breaking the egg at the little-end and breaking it at the big-end is trivial. Therefore, he suggests, that everyone does it in his own preferred way. We agree that the difference between sending eggs with the little- or the big-end first is trivial, but we insist that everyone must do it in the same way, to avoid anarchy. Since the difference is trivial we may choose either way, but a decision must be made."
Unread 26-02-2015, 13:20
SousVide SousVide is online now
SousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to behold
Don't forget that OP is in a AP CS course. Java is a tool to teach basic concepts in CS, not just programming, not just a specific language.
It's basically beginning course, in which you are learning the basic building blocks, vocabulary, and conventions. This is how people in the trade communicate with each other.
Unread 25-02-2015, 23:14
John's Avatar
John John is offline
AKA: John Gillespie
FRC #1153 (Roborebels)
Team Role: Mechanical
John is just really niceJohn is just really niceJohn is just really niceJohn is just really niceJohn is just really nice
How members of an array are stored and accessed is a function of the programming language. It is not something one should worry or argue about since the language will reference and de-reference everything for you. "Row" and "Column" mean nothing to the compiler. Notation has nothing to do with the physical location since memory is laid out so one accesses word-sized elements in sequence. In C and C++ matrices and arrays are really done with pointer arithmetic - google it.
I would disagree that you shouldn't care about how elements of a multidimensional array are stored. Knowledge of the underlying structure in physical memory can make a significant difference in performance of code.
Say you have a matrix that you are representing as a 2D array:
|a b c |
|d e f |
|g h i |
C/C++ structures this in row-major order. This means that the elements are physically arranged sequentially in memory in this order:
a, b, c, d, e, f, g, h, i
Fortran structures this in column-major order. Physically, they are represented as:
a, d, g, b, e, h, c, f, i
Each element is at a particular "address" in memory, which is usually expressed as a hexadecimal number. The elements of the array will be stored sequentially. This means that if element 'a' is stored at 0x1AFF3114, then (in C/C++) element 'b' will be stored at 0x1AFF3115, 'c' at 0x1AFF3116, and so on. In Fortran, 'd' would be at 0x1AFF3115, 'g' at 0x1AFF3116, 'b' at '0x1AFF3117' and so on.
Why does this matter? It is much faster to access elements sequentially than nonsequentially for most physical storage media, sometimes even orders of magnitudes faster. It won't make much of a difference for simple problems with 3x3 or other small matrices, but when dealing with very large matrices with thousands or even millions of elements (which appear in many real engineering problems, for example, the matrices created by FEA software-) it becomes very important.
As a result, it is useful to know what order your programming language lays out its multidimensional arrays in memory, and to write your algorithms to access them in sequential order when possible.
Unread 25-02-2015, 23:23
King Nerd III's Avatar
King Nerd III King Nerd III is offline
Chief Programmer/Head of Autonomous
AKA: Isaac
FRC #1410 (The Kraken)
Rookie Year: 2014
King Nerd III is an unknown quantity at this point
|a b c |
|d e f |
|g h i |
We were arguing over whether or not the computer stores them right next to each other in the matrix like I laid it out. The question on the quiz he gave was "True or false: The first set of brackets in a two dimensional array are columns, the second two are rows" and he put the answer as false. But that isn't really true, even if it is "convention" as he says. Which is why my Chief Engineer Rob Bob the Corncob and I said "no one cares about convention if you comment it enough" because if you comment it out the wazoo they'll know what you mean!
Unread 25-02-2015, 23:51
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
Rookie Year: 2007
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
If you have to comment your code out the wazoo, because you are breaking the conventions, you might be doing something wrong...
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 26-02-2015, 00:03
AKA: Isaac
Rookie Year: 2014
Oh, obviously. Good code should speak for itself! But we were just pointing out if you do something weird there is always the option to comment it!
Unread 26-02-2015, 00:06
AKA: Matt B
FRC #1771 (1771)
Rookie Year: 2007
Good code *probably* shouldn't break the conventions, unless it's really necessary. And if it is necessary, maybe reconsider your approach.
And commenting isn't really an option, it's more of a requirement, for anything! Think of it like homework that is assigned, but not collected. Sure, you MIGHT be okay not doing it every now and then, but really, you have to do it.
1771- Mentor (2015)
Unread 26-02-2015, 00:13
AKA: Isaac
Rookie Year: 2014
Usually my commenting system is describe variables, say what functions do, and explain certain things. But I went through a phase where I was super commenter, commenting every line! I think I was so tired once I commented a curly bracket. I think it said something like "I don't know why this is here, but I think it ends a function"
Turns out it ended an if statement. Boy was I tired.
Unread 26-02-2015, 00:44
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Too many comments is as bad as too few. Use descriptive variables, function names and constants then comment on the algorithm.
Unread 26-02-2015, 00:51
AKA: Isaac
Rookie Year: 2014
I think it really depends on who's going to be reading it. I usually comment as much as I can for teaching examples. But for personal projects I usually write the code and then go back and comment. If what I did doesn't make sense to me I will probably try to rewrite it in a less confusing manner, but if that isn't possible I'll comment it. I try to do this because if it doesn't make sense to me, the author, then it won't make sense to anyone!
  #15   Spotlight this post!
Unread 26-02-2015, 01:02
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Express your solution in a diagram or notation of some sort (UML or simple flow diagrams and so on) first. When you start coding, comment first and fill in the code afterwards. If your style is good, the code is readable and the comments explain the algorithm. Little else is really necessary no matter the audience.
