Go to Post STEM: Science, Trial, Error, Math. - hrench [more]
Unread 25-02-2015, 14:59
King Nerd III's Avatar
King Nerd III King Nerd III is offline
Chief Programmer/Head of Autonomous
AKA: Isaac
FRC #1410 (The Kraken)
Rookie Year: 2014
King Nerd III is an unknown quantity at this point
Inverting Talon SRX
So a few days ago we were putting together the code for an elevator and realized that the limit switches were backwards, basically the top limit switch stops it if it is going down and bottom stops it if it is going up. We are using the Talon SRX with the CAN bus and I was just wondering if there would be a way to invert it in the code? I know we can do it physically, and will probably end up doing that, but code would be much easier. I looked in the manual and couldn't find anything, so maybe it is hidden? I know with a Talon SR we can do random_motor->SetInvertedMotor(can't remember if it's bool); but it doesn't work with an SRX. Any ideas?
Unread 25-02-2015, 15:32
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
Re: Inverting Talon SRX
The procedure is documented in talon programming manual. But the "forward" limit switch stops the controller in the "forward direction" That might be down. Also if you are using normally closed limited switches you need to set that in the talon web dashboard. The default is N.O.
If you don't know what you should hook up then you should read a data sheet
Unread 25-02-2015, 15:39
AKA: Isaac
Rookie Year: 2014
I looked in the manual in there really is nothing as easy as random_motor->SetInvertedMotor(); which is inconvenient. A search of the manual brings up inverting a slave motor, but it doesn't really help. I think we will just stick with moving the forward limit switch to the bottom, and reverse to the top.
Thanks for the help!
Unread 25-02-2015, 15:47
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
You will need to fix it in the wiring. If the Talon is green (positive throttle) it will only check the forward limit switch. What causes the Talon to be green (closed-loop, slaving, slave-invert) instead of red (Reverse) can be controlled by Reverse Sensor and Reverse Closed-Loop output. But the limit switch is compared against the final output.
Unread 25-02-2015, 15:50
AKA: Isaac
Rookie Year: 2014
Yeah, that's what I thought. I wish we didn't have to do that, but as long as it works it's fine.
Unread 25-02-2015, 15:51
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
The SetInvertedMotor() method is generic to any motor speed controller. What makes you think it doesn't work with a Talon SRX?
Unread 25-02-2015, 15:56
AKA: Isaac
Rookie Year: 2014
The fact that when I do the following with a CANTalon object:
right_motor->SetInvertedMotor();
It says it can't resolve SetInveretedMotor(), and also the header files for both CANTalon and CANSpeedController do not have this method.
Unread 25-02-2015, 17:42
Software Architect
I don't see that method in the non-CAN Jaguar or Talon headers either. I'm pretty sure that's because it's a RobotDrive function. Are you able to get a random_motor->SetInvertedMotor(true); to compile when random_motor is a Talon SR, as your original post implies?
I should stop being subtle. It isn't working.
Unread 25-02-2015, 20:47
AKA: Isaac
Rookie Year: 2014
Nah, that doesn't work either. I agree that it is probably a robot drive thing, which won't help with an elevator.
Unread 25-02-2015, 22:45
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
FRC #1296 (Full Metal Jackets)
wireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond repute
Send a message via AIM to wireties
And like Omar said this is all internal to the Talon - when it is green it is looking for the "forward" limit no matter the software convention.
Fast, cheap or working - pick any two!
Unread 25-02-2015, 22:53
AKA: Isaac
Rookie Year: 2014
That kind of sucks, now we have to unsolder and all that. The last time we soldered was a nightmare, I don't want to go through that again!
We'll do it, though. For the team!
Unread 25-02-2015, 22:55
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Use connectors for all sensors and motors so they can be removed/replaced easily. It makes repairs (especially under stress) much easier.
Unread 25-02-2015, 22:59
AKA: Isaac
Rookie Year: 2014
We're using an encoder breakout board so it has to be soldered, we don't want to risk it coming apart. But we did this:
[board]~~wire~~[pwm connector][pwm connector]~~wire~~[sensor]
It works well enough!
Unread 26-02-2015, 00:53
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Rookie Year: 1997
jhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond repute
Is it really that important that forward be up!? I get that it's a little more straightforward, but if you reverse the output and make the top "red" and the bottom "green" then you don't need to rewire, right? You were wanting a software workaround, so a slight inconvenience of needing to invert a number seems reasonable.
  #15   Spotlight this post!
Unread 26-02-2015, 01:04
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
So just reconnecting the PWM-PWM interfaces for the 2 sensors should fix things?
