Go to Post This special is supposed to promote science, not convert the world to gracious professionalism (though that wouldn't be such a bad idea). - Karibou [more]
Unread 02-25-2015, 05:22 PM
Jeremy2145's Avatar
Jeremy2145 Jeremy2145 is offline
FRC #2145
Jeremy2145 is an unknown quantity at this point
USB Camera viewer in SmartDashboard
Is there any way to rotate the USB Camera viewer in SmartDashboard?
Time is as fluid as a dance, and truth as fleeting.
Unread 02-28-2015, 08:32 PM
msalihov msalihov is offline
AKA: Maxim Salikhov
FRC #5557 (BB-R8ERS)
Rookie Year: 2015
msalihov is an unknown quantity at this point
Re: USB Camera viewer in SmartDashboard
I do not believe so, I've messed around with SmartDashboard quite a bit. However if you are using an Axis camera (this is just from personal experience, other cameras might have this feature too,) you can adjust the rotation in the settings at your camera's IP (10.XX.XX.11)
Best of luck
Unread 01-27-2016, 09:15 AM
robert1356 robert1356 is offline
AKA: Robert Palmer
FRC #3824 (RoHAWKtics)
Rookie Year: 2012
robert1356 is an unknown quantity at this point
You could grab frames, rotate them using GRIP or NIVision filters and then push them to the SmartDashboard using CameraServer(). See the example code for grabbing frames and pushing them here: http://www.chiefdelphi.com/forums/sh...d.php?t=142633
