Thread Tools |
Rating:
Display Modes |
T-shirt Launcher
Hey guys so basically this is the year our team wants to go from meh to great. Our first objective was naturally sponors. We had 0 sponsors in the beginning of the season and now we have 4. The unforunate thing is we have money now but we need mentors and sponsors with machining facilities ad stuff of that nature.
So to attract those kind of sponsors we need to make something cool and something that can be used for event. We are also sponsored by cablevision now which owns madison square garden. Sooooo naturally t-shirt cannon is the idea that comes to mind. we have a drive train from I think 2010 that we are going to outfit with the new control system or just redo the wiring. Its just a standard kop chassi which is fine. The issue is the cannon itself. I saw a thread a while back with someone saying they would give a parts list. we have a bit of phenumatic experience and have supplies its just the speciallty stuff and how it works. It also cant completely break the bank. We have some money (1,100) and we were going to spend it all on supplies but we can get away with 750 in supplies leaving $350 for parts for the t-shirt cannon. thanks - Sam |
Re: T-shirt Launcher
You can make a really cheap and easy setup using a sprinkler valve. That's what we've been doing since we first built a t-shirt cannon. Basically you would store compressed air in a tank and then run a house to a sprinkler valve which would be attached to the back end of the barrel. The valve is triggered electrically.
Whatever you end up building, please only use parts rated for AIR pressure. This means no PVC pipe or lawn sprinkler valves.
I would recommend copper or brass piping for any pneumatic operations dealing with such large volumes of air due to the fact that it is actually rated for air pressure and less likely to shatter if it does fail. Last edited by Whippet : 26-02-2015 at 02:58. |
Would the setup be Compressor, storage tank (probally something cheap and dirty from harbor freight, and then to the sprinkler valve. Or would it be pump large storage tank solenoid to regular storage tank.. Sorry for being such a noob just want to make sure I know what to do myself before I design and lead the build. |
We built a t-shirt cannon last season to get practice for build season
https://www.youtube.com/watch?v=btgNmKMj8qg We used a harbor freight 5 gallon air tank, made accumulator tanks out of abs pipe, used sprinkler valves, and reused electronics from old seasons. If you have questions, feel free to ask |
We're building a t-shirt cannon as well and we are using a copper tube for our barrel. |
Also what are the special parts you actually had to go out an buy like stuff most people don't have laying around. Thanks |
#10
The one we built was in the neighborhood of $5000 just for parts. But we started from scratch. The custom sheet metal chassis, paint job, and specialty designed adapter block to go from the solenoid to the barrel was donated, everything else we bought.
We are using twin scuba tanks. The pneumatic system was designed by a colleague who is a PE in piping design. We have several safety rated devices (Burst discs) in the lines so that we don't over pressurize the system. |
#12
It isn't a myth though. PVC isn't rated for air pressure and when it fails it does so spectacularly. It will work fine for a while, you just won't know when that while will end. And when that time comes, the result will at the least let blood come out of someone. The worst case scenario is much, much worse.
#13
There's always a hot dog shooter. Definitely not PVC level, as Philly Phanatic can get them into the upper seats and needs a license to shoot. Story and video here.
Now I want a hot dog! |
#14
Unfortunately, if you can't afford to do it with the proper materials, it's probably not worth the possibility of serious injury in the end.
#15
We shoot about 100 feet with something like 20psi. Pvc will not burst at 20psi. Look into 12v air horn solenoids instead of sprinkler valve both work well
