Go to Post To sum it up... We know nothing. - BJC [more]
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Unread 26-02-2015, 01:18
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
The math of the cans...
So after discussing with some of my team members about whether we should make our step can grabbers faster (Yes!) I decided to run some numbers on whether it would be worth it in elims to grab, say, 2 cans, faster than anybody else. Or 4 cans but remove something major from our bot.
Or literally have a bot made of can grabbers that grabs all 4 cans in a fraction of a second, using superior firepower (all the cims + as many motors and pneumatics as you can fit in that 120lb-limit), plus our drivetrain for shoving noodles or totes.
I am not counting the value of noodles due the unknown factor in how long it takes to put them in cans or how many can fly to the other end of the field.
Most of this is calculated with a 3-stack assumption for really good teams. This is lowballing IMO, but you can see at the end that more stacks/ team means a more effective can grabber.
With 2 cans to each alliance, then it's evenly matched points-wise per alliance. If, in one match, an alliance can score 5 full stacks of totes + can (not counting noodles here) and one non-can stack that's
36 points/stack * 5 stacks + 12 points for non-can stack = 192 points.
A high number, to be sure, but doable depending on where you are (thankfully, my team is not attending Dallas lol). With no cans, only the 3 you begin with, then you run a point total of
36*3 + 12*3 (tote-only 6-stack) = 152 points.
Okay, that's not too bad, your average still remains relatively good, especially if against other teams you can match taking 2 cans off the step. Plus, you can still score totes instead of picking up cans once you run out to lessen the impact. The other team still gets only 192, which could be beatable overall with other elims scores.
TL;DR: If a really good robot this year can score 2 canned stacks (as in, that's the effective maximum for even the really good teams) then the can grabbing bot is somewhat ineffective in elims. Very situation-specific as to its other capabilities.
But...
If two alliance members can stack 3 fully loaded stacks, and the can grabber can only grab 4 cans, then that's a total capacity of
6*36 = 216 points.
with canned stacks. By contrast, if you can only get 2 cans off the step and a decent stacker (2 loaded stacks) with the two good stackers that's
5*36 + 3 * 12 = 216 points.
TL;DR: At any level of competition, two demon-stackers and a decent stacker w/ two-can grabber would do as well as an alliance containing a bot that grabs 4 cans and flops over with two demon-stackers. If the can-grabbing-flopper can cap 6-tote stacks with cans or load cans with noodles or something, then it has the upper hand.
If an alliance with the capability to get 4 cans the fastest makes it to semis, then it gets very interesting. Because each team plays 2 matches, and there's only 4 teams playing, a lowered score due to loss of the cans could impact the score enough to outweigh the fewer points that a specialty can-grabbing bot would make compared to a fast stacker.
Using the 3-stack/bot model,
4-Can grabber alliance:
6*36 = 216 points.
Other alliance:
3*36 + 6*12 = 180 points.
In matches without facing the 4-can grabber, but still obtaining two cans:
5*36 + 4*12 = 228 points.
Cutting it pretty close there at 228 vs. 216. But, at 6 matches worth 228, and 2 matches worth 180, the average is only 216 points! What an interesting coincidence.
So if you have that 4-can flopper, pushing some noodles around could possibly win you semis.
TL;DR: A 4-can bot that does nothing else can tie with an alliance made of really good stackers if it has stackers of similar level oiance in semis. It can beat the opposing alliance if it can push stuff around or do anything other than flop over.
On Einstein, the 4-can-and-flop is an almost guaranteed win. If every robot there can make, say, 3 loaded stacks over the course of the match, this is the flopper's alliance:
6*36 = 216 points.
This is the other alliance:
In order to beat the flopper's alliance, the opposing alliance has to score an additional 18 totes. That's 3 extra stacks, or essentially one entire extra stack per robot on an alliance. And everyone's on Einstein here. 3 stacks is a lot of upper hand.
I'll have to wait until Dallas to see what the metagame is- how many stacks can the best of the best get? 3? 4? 5? The more stacks they can make, the more effective the can-grabber-flopper bot becomes (assuming the alliance is made up of good robots), as it becomes increasingly likely that they can score all 7 canned stacks every single match, and the opponent's average score drops even lower.
Take Einstein again. The opposing alliance has to make do with 3 cans. With only two functioning robots on the flopper's alliance after auton, at a capacity of 4 stacks per non-can bot, the flopper alliance makes
7*36 + 1*12 = 264 points.
Compared to
3*36 + 9*12 = 216 points for the no-canners.
AKA 24 extra totes to score to catch up. I'm not doing the math for semis, but I think it's still going to be pretty close for a can grabber vs. everybody else with higher points totals, although the can grabber would have a better upper hand.
So to summarize:
-On Einstein, cans are important. It could all be decided in the literally the first second.
-In elims, cans are important, but not as much. A can grabber has to still carry its weight, at least a bit.
-If a really good robot can stack 3 canned stacks per match, then a 4-can grabber is about equal to a 2-can grabber with 2 canned stackes in a match.
-If the metagame is 3 stacks/bot, then the 4-can-grabber is pretty good. As the metagame gets better, to 4 or even 5 stacks per robot, the value of the can grabber becomes much higher to the point of being overpowered.
-If a very high-seed team with 2-can grabber picks the next fastest 2-can grabber, it stands poised to win if it can pass through quarterfinals.
Personally I wouldn't want to build just a 4-can grabber as the robot unless we spent all season getting the code and mechanism perfect to the point where it was a guaranteed grab of all 4 in 1/10th of a second, and I knew it was impossible to be faster than us.
Which is totally possible.
Thoughts and errors in my concepts? Assuming all tote stackers are created equal is a fallacy, but it doesn't look like there will be a massive fissure between the fantastic teams and the good teams this year. Still, the 4-can flopper has to do something else other than grab the cans...
Unread 26-02-2015, 01:29
faust1706's Avatar
faust1706 faust1706 is offline
FRC #1706 (Ratchet Rockers)
Rookie Year: 2011
faust1706 is infamous around these partsfaust1706 is infamous around these parts
Re: The math of the cans...
I hope on einstein both teams can grab all 4 bins from the middle, and they all grab them at the same time and it comes down to whose grabber is stronger.
"You're a gentleman," they used to say to him. "You shouldn't have gone murdering people with a hatchet; that's no occupation for a gentleman."
Unread 26-02-2015, 01:31
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
Zip ties on the can or just can shear is my guess. Those things are only so strong.
They might end up simply getting rid of the center cans or something. Nobody could let go for the entire match.
Unread 26-02-2015, 01:50
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is offline
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Team Role: Coach
AllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond repute
Send a message via AIM to AllenGregoryIV
Gamesense had a good discussion on this. Your alliance still has to execute even if you get all 4 cans off the step. A knocked over stacked could end an alliances hope at making it out of any round.
Also noodles in the RCs mean that the opposite alliance needs another 3 totes per stack to catch up. There is something to be said for efficiently noodling the cans and ensuring the noodles stay in the cans. One of the reasons why so many people are amazed by 148 is their ability to play two different roles. They can both acquire cans, put noodles in them and put them on top of stacks while they stack at the same time. If that gives them an extra stack or possibly two out of the feeder station (say 4 or 5 by one robot with littered RCs on top) that is a huge advantage.
The average stacks per robot gets harder as more good teams get on an alliance. 30 totes behind the glass (5 stacks) and 18 right side up in the landfill (3 stacks). The 9th stack is likely way slower for even the best alliances since it's either upside down or pulled from the step.
The arms race (as talked about on GameSense) will be very interesting this year. It's going to be like 2011 but worse since teams can keep throwing power, weight, and design time at it. 3310 has set the bar at their reported 1/4 sec pull. I'm waiting for the 1st team to start wind tunnel testing their mechanism to reduce drag.
Team 647 | Cyber Wolf Corps | Alumni | 2003-2006 | Shoemaker HS
Team 2587 | DiscoBots | Mentor | 2008-2011 | Rice University / Houston Food Bank
Team 3847 | Spectrum | Coach | 2012-20... | St Agnes Academy
LRI | Alamo Regional | 2014-20...
"Competition has been shown to be useful up to a certain point and no further, but cooperation, which is the thing we must strive for today, begins where competition leaves off." - Franklin D. Roosevelt
Unread 26-02-2015, 02:08
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
FRC #3310 (Black Hawk Robotics)
Rookie Year: 2010
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
start wind tunnel testing?
Unread 26-02-2015, 02:10
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
Common, who doesn't like seeing an entire season decided in less than a quarter of a second?
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 26-02-2015, 02:19
faust1706's Avatar
Rookie Year: 2011
that's how breakaway was on einstein. If you didn't stop....469(?) in autonomous you lost the match.
Unread 26-02-2015, 02:22
Andrew Lawrence
Posts: n/a
469(?)
Yes, 469.
Unread 26-02-2015, 10:28
Josh Fox Josh Fox is offline
AKA: Foxy
FRC #0027 (Team RUSH)
Rookie Year: 2007
Josh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud of
You may want to take a look at the way things turned out again...
Team RUSH Alumnus and Mentor, Mechanical Engineer
Unread 26-02-2015, 11:27
Hallry's Avatar
Hallry Hallry is offline
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Rookie Year: 2010
Not necessarily...
Unread 26-02-2015, 15:23
x86_4819's Avatar
x86_4819 x86_4819 is offline
computer-whisperer
AKA: Christian Balcom
FRC #4819 (Flat Mountain Mechanics)
Rookie Year: 2013
x86_4819 is on a distinguished road
For those of us that weren't involved in FRC back then, what did they do that was so great?
My Github Repositories
Unread 26-02-2015, 15:25
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
Navigated to the platform and mechanically locked themselves in position to roll all the balls returned into play back into the goal.
Unread 26-02-2015, 15:33
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
They did it so smoothly that it looks like that's what was supposed to happen. You have to watch another match from that year to appreciate it.
Unread 26-02-2015, 15:55
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
This was not something that was easy to do within the framework of the rules that year, either.
Does anyone else remember when TBA signatures actually worked?
  #15   Spotlight this post!
Unread 26-02-2015, 17:09
Lil' Lavery Lil' Lavery is offline
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
Nobody stopped 469 in autonomous on Einstein.
469 didn't win Einstein.
Even with an overwhelming strategy, you still have to execute. Getting the cans alone is not a chokehold strategy.
