Go to Post What's a pirate's favorite robotics tournament? Aye-arrrrrrrrrr-aye, matey! - John Wanninger [more]
Unread 02-03-2015, 13:53
crollison crollison is offline
AKA: Chris Rollison
FRC #4809 (Black Knight Robotics)
Team Role: Coach
crollison is an unknown quantity at this point
Labview and programming gradual start/stop
How do you program so that the robot has to gradually start/stop. We are a little top heavy and need to reduce inertia. Looking at the examples and I don't think that the Joystick Response Curve is the right thing? Thanks for any help.
Unread 02-03-2015, 13:55
pastelpony's Avatar
pastelpony pastelpony is offline
Programmer/Electrical
AKA: Zach M
FRC #3525 (Nuts and Bolts of Fury)
Rookie Year: 2013
pastelpony will become famous soon enough
Re: Labview and programming gradual start/stop
What do you mean "gradually start/stop" ? Do you want to throttle the speed of your drivetrain?
Team 3525 Head Programmer (2014- ) - Java (Formerly LabVIEW)
Unread 02-03-2015, 14:00
AKA: Chris Rollison
Team Role: Coach
So that when you jam the joystick forward, it doesn't immediately go full speed.
Unread 02-03-2015, 14:22
pastelpony's Avatar
AKA: Zach M
Rookie Year: 2013
Multiply your joystck inputs by their absolute value. This squares the inputs, only allowing full speed at a full push. For example, what would normally be 0.5 would be 0.25 and -0.9 would be -8.1 etc.
Unread 02-03-2015, 14:24
Nyxyxylyth Nyxyxylyth is offline
AKA: Neal Manson
FRC #1481 (The Riveters)
Rookie Year: 2013
Nyxyxylyth is just really niceNyxyxylyth is just really niceNyxyxylyth is just really niceNyxyxylyth is just really niceNyxyxylyth is just really nice
If you're using CANTalons, consider letting them do the heavy lifting by using Set Voltage Ramp. See 6.1 in the TALON SRX Software Reference Manual. Consider something like 0.33 (1 second for 0-33%; 3 second ramp from 0-100%).
Unread 02-03-2015, 14:31
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
If you look closely at the Tank Drive and Arcade Drive VIs, this is already done for you by default. Though this will not accomplish what was asked. If you jam the joysticks forward with the squared inputs, you will still go full speed immediately.
What you are asking is described fairly well here starting at post #8: http://www.chiefdelphi.com/forums/sh...d.php?t=125439
I attached a LabVIEW example at the end in post #10. If you search for the VI "PID Output Rate Limiter" you will get a VI that works well for this, and you can adjust the ramp time.
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Chris Hibner's Avatar Unsung FIRST Hero
Chris Hibner Chris Hibner is offline
Eschewing Obfuscation Since 1990
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Rookie Year: 1997
Chris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond repute
Use the PID rate limit VI which can be found in the control & simulation -> PID palette.
See attached image.
An ounce of perception is worth a pound of obscure.
