Go to Post Success is the indescribable feeling you get when you see something you worked so hard on in front of thousands of people. - SlamminSammy [more]
  #16   Spotlight this post!
Unread 03-03-2015, 16:09
electroken's Avatar
electroken electroken is offline
Electron Tamer
AKA: Ken Pontbriant
FRC #0230 (Gaelhawks)
Rookie Year: 2012
electroken is a jewel in the roughelectroken is a jewel in the roughelectroken is a jewel in the rough
Re: Intake Motors...
Originally Posted by Ether View Post
Do you have a picture of that you could post? So many rookie teams ask for advice how to mount limit switches. It would make a good reference link. Thx.
If it wasn't for that big ol' bag on the robot...
Now I have a reason to get that switch onto the practice robot.
Our frame serves as the mechanical stop for the totes, extending the life of the switch to beyond one cycle.
  #17   Spotlight this post!
Unread 03-03-2015, 16:11
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Yeah, that's what I'm talkin' about
  #18   Spotlight this post!
Unread 03-03-2015, 23:53
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
How do you prevent the motors from stalling as the intake completes?
Two other techniques we considered for our ball pickup last year are:
  1. Make the frictional force low enough that when the game piece is fully in place, the wheel slips. Problems with this method include possibly reduced intake force and rapid wear on your rollers.
  2. Monitor the current draw on the motor and cut it off quickly when it spikes. This used to require custom current sensors, which we had purchased from pololu, but now they're built into the power distribution panel.
Last year we used our solution number one, as the balls were compliant and not much force was needed to pull them in; it may not be a good solution this year.
  #19   Spotlight this post!
Unread 04-03-2015, 12:29
charby611's Avatar
charby611 charby611 is offline
FRC #4607 (C.I.S.)
Team Role: Leadership
Rookie Year: 2012
charby611 is an unknown quantity at this point
Originally Posted by GeeTwo View Post
The PG27 will run almost three times as fast as the PG71. The gearbox is available separately, and will be a direct replacement, no resizing of other components should be needed.
http://www.andymark.com/product-p/am-0915a.htm
^^^^ Is this what you are talking about because i believe I am going to place an order for these right now..
  #20   Spotlight this post!
Unread 04-03-2015, 12:40
silverD's Avatar
silverD silverD is offline
Build Mentor
AKA: Nate
FRC #2052 (KnightKrawler)
Rookie Year: 2007
silverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to beholdsilverD is a splendid one to behold
There are options. If you just want the gearbox, gearbox with 500 series motor, or gearbox with RS775 series motor. Please ensure the motor you use is one that is allowed from R18 in the manual. There are also PG series parts that may be of interest as well.
Nate
  #21   Spotlight this post!
Unread 04-03-2015, 12:51
Libby K's Avatar
Libby K Libby K is offline
Always a MidKnight Inventor.
FRC #1923 (The MidKnight Inventors)
Rookie Year: 1992
Libby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond repute
Originally Posted by SJaladi View Post
We're using BAG motors with a 100:1 VersaPlanetary gearbox running 4" colsons. While it intakes totes a little slower than some of the other designs out there we found that the higher ratio gives us enough torque to allow for some misalignment on the totes and still reliably intake them.
I swear to you, Sarath, I came here to post this, read your post and was about to send it to you, like 'Hey! Someone else did it our way too!" ...Whoops.
Something we did notice during driver's practice is that with our wheels running, simply touching a tote from with the outside of the intake (read: we're not at -all- lined up to grab that tote, off by a huge angle) breaks up the cluster of the Landfill pretty quickly and gets the tote lined up for us to better close in on it. So, while our actual tote intake is a bit slower, we can get individual totes lined up for capture with very little effort.
Libby Kamen
Team 1923: The MidKnight Inventors
2006-2009: Founder, Captain, Operator, Regional Champion.
2010-Always: Proud Alumni, Mentor & Drive Coach. 2015 Woodie Flowers Finalist Award.
229: Division By Zero / 4124: Integration by Parts
2010-2013: Clarkson University Mentor for FLL, FTC & FRC
FIRST Partner Associate, United Therapeutics
#TeamUnither | facebook, twitter & instagram | @unitherFIRST
questions? comments? concerns? | twitter: @libbyk | about.me/libbykamen
  #22   Spotlight this post!
Unread 04-03-2015, 12:57
Andrew Lawrence
Posts: n/a
Depending on the game, a good rule of thumb I like to go by is to always gear your intake a bit faster than the speed you'll likely be approaching the game piece at. For example, in 2014, many teams approached the balls on the ground pretty quickly, and if their intake was slower than their drive speed they'd end up pushing the ball around with them as they drove. Teams who geared their intakes faster than the speed they were approaching the balls at could drive up to one and have it in their possession almost instantly.
This year most teams aren't going to be approaching totes and bins head on at high speeds (let's hope they don't, at least), so while intakes should be fast, they won't have to be as fast as they have been in previous years.
  #23   Spotlight this post!
Unread 04-03-2015, 13:14
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Rookie Year: 2013
Yes, that's the PG27 with the motor and the rear axle extension for an encoder. That extension may be a problem if you currently have short clearance behind the motor, but it'll save a swap out step if that's OK. If you just want the PG27 gear box for $14 less, it's here:
http://www.andymark.com/product-p/am-2937.htm
