Go to Post (middle school age) One time I had a truly awful day at school and came home crying. My mother's response? "Do you want to go to the build session tonight? It will make you feel better.." And it did. It always does. - rachelholladay [more]
Unread 03-03-2015, 21:55
VaneRaklan VaneRaklan is offline
FRC #2557 (The SOTABots)
Rookie Year: 2014
VaneRaklan is an unknown quantity at this point
Autonomous: addParallel
So we are trying to run parallels in our autonomous, but for some reason when we add a parallel to the mix, that command won't run until after every other sequential command has finished. Any ideas for why this would happen? If someone could put up an example of a simple, working, auto code that uses parallels, t that would be great.
Unread 03-03-2015, 22:13
TFleig78's Avatar
TFleig78 TFleig78 is offline
AKA: Tyler
FRC #0078 (Air Strike)
Rookie Year: 2012
TFleig78 will become famous soon enoughTFleig78 will become famous soon enough
Re: Autonomous: addParallel
I believe a parallel command won't run until the sequential command above it has finished. if you want two things to happen simultaneously, make the first one parallel.
This is a snippet of our code from last year:
Code:
          addSequential(new ShootAndReloadBall());
          addSequential(new WaitCommand(0.75));
          addParallel(new IntakeFastStore());
          addParallel(new DriveStraight(DRIVE_SPEED, DRIVE_TIME));
The last two commands execute at the same time.
Unread 04-03-2015, 03:31
gixxy's Avatar
gixxy gixxy is offline
Programming and Arduino Mentor
AKA: Gustave Michel III
FRC #3946 (Tiger Robotics)
Rookie Year: 2012
gixxy is on a distinguished road
Just to make sure everything is clear.
Code:
          addSequential(new DriveStraight(DRIVE_SPEED, DRIVE_TIME));
Will also have the last two commands run at the same time.
The addX() functions basically apply to handling the next command's execution order.
Programmer - A creature known for converting Caffeine into Code.
Studying Computer Science @ Louisiana Tech University
Associate Consultant @ Fenway Group
2012-13: 3946 - Head of Programming, Electrical and Web
2014 - 3468 - Programming Mentor
2015 - Present - Lurker
Unread 04-03-2015, 07:36
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
mwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond repute
Deleting my post because I was wrong in several of my assumptions.
Thanks Matt for correcting me.
Needless to say, adding parallel commands can certainly make your head spin.
Good luck!
"Never let your schooling interfere with your education" -Mark Twain
Unread 04-03-2015, 10:46
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
notmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond repute
If we convert this into the translated syntax you'll come up with this.
Code:
[2|1]
[3]
[4]
What you'll notice is that 1 will only execute as only as 2 executes. If 2 finishes, 1 also finishes, even if it's not done.
Looking at the source code for CommandGroups I do not believe this is the case. Command 1 will run until another command that requires the same subsystem interrupts it or it finishes on its own.
So when you are implementing a series of parallel commands in a command group they need to be followed by the sequential command which acts as the control for the command.
Code:
addParrallel(1);
addParrallel(2);
addSequential(3);
In this case the command group will run until 3 finishes.
I also do not believe this is the case. The CommandGroup will not finish until all commands it contains are finished.
Unread 05-03-2015, 14:12
shindigo shindigo is offline
AKA: Mike Parker
FRC #0102
shindigo is an unknown quantity at this point
We put all our sets of parallel commands in their own CommandGroup. We find this makes is clearer what is running in parallel and what is not.
In the Autonomous CommandGroup we have:
AddSequential(new DoThing1());
AddSequential(new DoThings2and3());
AddSequential(new DoThing4());
Inside the CommandGroup called DoThings2and3 we have:
AddParallel(new DoThing2());
AddParallel(new DoThing3());
Thing4 does not execute until 2 and 3 are finished.
Unread 05-03-2015, 14:16
Ty Tremblay's Avatar
Ty Tremblay Ty Tremblay is offline
Robotics Engineer
Ty Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond repute
It's a little counter intuitive at first, but addParallel() commands run in parallel with the first addSequential() AFTER them.
Code:
addParallel(1)
addParallel(2)
addSequential(1)  //All 3 commands run
addSequential(1)
addParallel(1)
addParallel(2)
addSequential(2) //sequential 1 will run, then parallels 1&2 will run with sequential 2
