Go to Post I would like to complain about the game as well. Complain, complain. - Monochron [more]
Unread 03-03-2015, 23:20
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Rookie Year: 2013
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
pic: Poly-carbonate Gearbox Plate
Unread 03-03-2015, 23:26
Joe G.'s Avatar
Joe G. Joe G. is offline
Taking a few years (mostly) off
AKA: Josepher
no team (Formerly 1687, 5400)
Rookie Year: 2007
Joe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond repute
Send a message via AIM to Joe G.
Re: pic: Poly-carbonate Gearbox Plate
I have done several gearboxes with polycarb side plates in the past few years.
I have not ever done so except in extremely low speed/low load applications, but I would definitely not recommend ever using polycarb as a bearing surface. It's actually comparatively rough on machined or cut surfaces, and doesn't do as well in wear as plastics like delrin. Just make some kind of adaptor plate for the encoder, and put your mount holes somewhere else.
I would also not suggest blindly copying the lightening pattern of the aluminum plate to the polycarb. It is much more flexable than aluminum, and the thin ribs will cause the bearing holes to twist quite easily. I always do my polycarb gearboxes with solid side plates (the shift from aluminum to lexan is plenty of weight savings for us), and consider a more aggressive standoff pattern to stiffen it up as well.
FIRST is not about doing what you can with what you know. It is about doing what you thought impossible, with what you were inspired to become.
2007-2010: Student, FRC 1687, Highlander Robotics
2012-2014: Technical Mentor, FRC 1687, Highlander Robotics
2015-2016: Lead Mentor, FRC 5400, Team WARP
2016-???: Volunteer and freelance mentor-for-hire
Unread 04-03-2015, 00:00
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Can you fit an Igus type plastic bushing in there? or a bronze bushing?
And yeah, all those irregular holes look like a waste of machining time, but then I'm a naturally lazy person.
Unread 04-03-2015, 00:46
Chris is me's Avatar
AKA: Pinecone
You can't afford to use the kind of aggressive lightening patterns in polycarb that you can in aluminum, particularly for gearboxes. Polycarbonate just isn't rigid enough. I would not pocket the gearbox at all, and maybe add more counterbores standoffs to give you rigidity. All of the rules for pocketing aluminum gearboxes just don't apply here.
To answer your question, could you run a shaft in polycarb without a bushing... Maybe, but probably not at 1200 RPM. You could easily heat the polycarbonate up to its glass transition point wih aggressive driving and things would get ugly fast. Even if it works though, your efficiency will tank beyond the point where it's worth it. An encoder is a terrible reason to throw out ball bearings...
Unread 04-03-2015, 00:47
Munchskull's Avatar
Team Role: CAD
Rookie Year: 2013
I definitely can/will/did remove the lightening holes. I can fit a bushing if I have to, I just wanted to check before if got them.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 04-03-2015, 00:55
Joe G.'s Avatar
AKA: Josepher
Rookie Year: 2007
I would tend to agree with Chris, that I wouldn't even go as far as to swap from a ball bearing in an application as crucial as a drivetrain. Just use a mount plate like this, you'll be much better off.
Unread 04-03-2015, 01:06
Munchskull's Avatar
Team Role: CAD
Rookie Year: 2013
I thought as much. My belief has been to design dangerously but build safely. I will see if a bronze bushing will work. We have two extra gear box's that would use this plate, I think that I will make and install one with a bushing and run the gearbox for a good two hours on full checking in at ten minute intervals (don't worry someone will be in the room) and take picture for records. while it may never go on a robot it would be a great learning experience for designing with plastic.
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 04-03-2015, 11:34
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
FRC #0973 (Greybots)
Rookie Year: 2012
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
For that to be a realistic test, the gearbox must be put under loads similar to what it will see on an frc robot. Testing it as you described, with no load, will not expose any potential problems fully
(2015-?): 973
(2012-2015): 955
