Go to Post Mentors can never receive enough thanks from us students, who don't know even half of what they put into our teams. - Katie_UPS [more]
Unread 04-03-2015, 15:05
jtrv's Avatar
jtrv jtrv is offline
github.com/jhtervay
AKA: Justin
FRC #2791 (Shaker Robotics)
Rookie Year: 2012
jtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to all
Question Does any code run while the laptop is connected to the field,but the bot is disabled?
Hi guys,
I'm wondering if there is any code that runs while your laptop is connected to the field via ethernet but the robot is disabled. Currently using IterativeBot in Java if there's a method we can override that I'm missing.
Thinking about calibrating some wonky gyro on the field because if we do it in the pits it'll get all wonky and it's too hard to explain the gyro situation here and the gyro is bagged anyway.
We'd have a limit-switch type object that we press on the bot itself and it will calibrate, turning on a certain LED while it is calibrating, and turning off when done.
Anybody know? Thanks a bunch ^^
Unread 04-03-2015, 15:18
MrRoboSteve MrRoboSteve is offline
Mentor
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
Rookie Year: 2011
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Re: Does any code run while the laptop is connected to the field,but the bot is disab
overriding disabledInit() or disabledPeriodic() sounds like a match.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 04-03-2015, 16:15
jtrv's Avatar
github.com/jhtervay
AKA: Justin
Rookie Year: 2012
That's what I thought too, but I honestly wasn't sure if FIRST had a safety system where literally no code will run while your laptop is connected to the field. So i don't know. There's not much of a way to test it until we get there, either, unfortunately.
Unread 04-03-2015, 16:18
alopex_rex's Avatar
alopex_rex alopex_rex is offline
Rainbow Professionalism Dash
AKA: Scott Morton
FRC #0830 (The RatPack)
Rookie Year: 2012
alopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond repute
To the best of my knowledge, anything that could run an actuator (so all PWM, digital output, etc) cannot be used when the robot is disabled, but your code still runs. I know because our (C++) program prints to the smart dashboard in DisabledPeriodic().
Ratpack programming lead 2013 - 2015
ἔκλαγξαν δ᾽ ἄρ᾽ ὀϊστοὶ ἐπ᾽ ὤμων χωομένοιο / αὐτοῦ κινηθέντος: ὃ δ᾽ ἤϊε νυκτὶ ἐοικώς. (Ancient Greek nerds unite!)
Unread 04-03-2015, 16:27
adamm adamm is offline
AKA: Michael Adam
FRC #1671 (The Bird Brains)
adamm is just really niceadamm is just really niceadamm is just really niceadamm is just really niceadamm is just really nice
Yes, all output controls are disabled when the robot is disabled (safety feature), however, you can still initialize sensors (calibrate gyros, etc), load values from preferences, etc.
Michael Adam
Director, Central Valley Robotics
FLL and FLL Jr. Affiliate Partner, Central California (2009-Present)
Member, Central Valley Regional Planning Committee (2012-Present)
Volunteer of the Year, Central Valley Regional (2015)
FRC Control System Advisor (2013-Present)
FRC Scorekeeper (2015-Present)
Mentor, Team 1671 (2009-Present)
Member, Team 1671 (2005-2009)
Unread 04-03-2015, 16:46
jtrv's Avatar
github.com/jhtervay
AKA: Justin
Rookie Year: 2012
Our gyro is a digital gyro that plugs into the SPI port. Will code be able to access that? We initialize it at SPI.Port.kOnboardCS1 ... Yes, we had to write our own driver in Java... it sucked, but it works (kinda).
Unread 04-03-2015, 16:53
AKA: Michael Adam
Yes, Anything that works now will work the same on the field. (Well, its intended to, sometime the field likes to do other things though). Read more about how the field controls your robot here: https://wpilib.screenstepslive.com/s...fms-whitepaper
Michael Adam
Unread 04-03-2015, 21:12
jtrv's Avatar
github.com/jhtervay
AKA: Justin
Rookie Year: 2012
This is great. So that means disabledPeriodic() runs before the match starts?
Unread 05-03-2015, 14:44
AKA: Michael Adam
It should, yes.
Michael Adam
Unread 05-03-2015, 15:25
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
It should, yes.
The code will run, but note that you can't activate any motors or solenoids while the robot is disabled for what I hope are obvious reasons.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
