Go to Post I know my grandmother would call me a bully for that. And she didn't raise a bully. - Libby K [more]
Unread 05-03-2015, 09:38
DCRich DCRich is offline
Mentor
FRC #2180 (Zero Gravity)
DCRich is an unknown quantity at this point
Unable to Update wpilib in Eclispse
I tried to update the wpilib plugins and I get a message that no programs are available. I tried to download and do the install offline and I get he same message. Yet I can see the files in the archive. When I attempt to access the http://first.wpi.edu/FRC/roborio/release/eclipse/ it returns an error, "Access Denied" My plugins are at least 2 revisions behind.
Anyone know why Eclipse would not be able to import the new plugins or why it cannot access the recommended link?
Unread 05-03-2015, 13:46
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
SuperBK is just really niceSuperBK is just really niceSuperBK is just really niceSuperBK is just really nice
Re: Unable to Update wpilib in Eclispse
Is this on Linux, Mac, or windows?
It might be that the account you are running Eclispe under doesn't have permission to write to the folders. Try running as administrator or sudo if Linux.
Check to make sure that your eclipse and your jvm that's its running under are up to date. Look at "Help->Installation Details->Configuration tab"
Clean out any previous attempts to install from a file system under
Windows->Preferences->Install/Update->Available Software sites". Look for anything that says "FRC". You could delete the existing site and add it back in again, but that's up to you.
Saw this on Linux: Check the case sensitivity of the link. What you pasted here looks correct, but make sure that's the one you are entering in eclipse is correct.
And finally, a last ditch effort: Try with and without the trailing slash.
Brian K
Team 1225 Robotics Mentor
Unread 05-03-2015, 15:13
JacobD's Avatar
JacobD JacobD is offline
AKA: Jacob
FRC #1672 (Mahwah Robo T-Birds)
Team Role: Leadership
Rookie Year: 2013
JacobD is an unknown quantity at this point
Quite honestly, you shouldn't update. If you check the requirements, it does not say anything about having to update the libraries. Plus, when I updated mine, I got a ton of issues with my cameras. Just leave it how it is and update the driver station.
