Drive Systems
I've been noticing the many different styles of drive systems, such as tank, mecanum, H-drive, and swerve. I was wondering what other people have seen and built for there robots.
Re: Drive Systems
Tank is the basic and, in my opinion, the best drive for most teams. It is simple and effective. I believe that even in RR tank is superior. This is most often a 6 wheel, dropped center. Sometimes you will see an 8 wheel dropped center. It provides the best traction so you get pushing power and acceleration.
The main disadvantage of tank is the inability to move sideways. Mecanum is often used to move sideways. I am not a programmer, but from what I understand it requires rather complex programming. When done well, it is easy to use, but can be easily messed up. It provides poor tration and is easily pushed around. H drive uses omni wheels mounted perpendicular to each other. Omni wheels hame small rollers that allow them to slide sideways, so there is a set of wheels for each direction. It has the same low traction as mecanum. Swerve is often considered the best overall drive. It has great traction and has sideways/diagonal/any direction movement. Each wheel is mounted on a pivot so it turns beneath the bot. These are very difficult to build but are very versatile. One of the most interesting drives I have driven is one developed by team 967. This 9 wheel drive used an 8 wheel dropped center base, with one wheel mounted perpendicular and on a piston. When the piston is activated the wheel is forced down and the back end of the bot lifts off the ground, so it is supported by the two front wheels and the 9th wheel in the center of the bot. This allows great traction in regular tank mode and the ability to move sideways. I believe in 2014 Team Titanium utilized this concept in their drive base. What else is out there? |
Re: Drive Systems
1114 is using kiwi drive this year. Three omnis set in a triangle.
Re: Drive Systems
There were a few Killough (4 wheel omni). Here's one At least one octocanum. And don't forget the... kiwi swerve? not sure what overclocked is calling this. |
Re: Drive Systems
Team 1923 built a custom drivetrain this year that incorporates some of the best qualities of different variations of tank drive. It is constructed with C-channel like a standard tank drive, but similarly to a WCD one wheel on each side is direct driven by the gearbox allowing for us to drive to some extent even if all the chains fail. Additionally to prevent damage to the chain we run all the chain within the c-channel. The drivetrain has 5 wheels on each side (3 colsons in the center and 2 omnis out at the ends). It does not use a drop center but rather relies on the omnis out at the ends to facilitate turning with minimal scrub. We chose to use 5 wheels on each side so that we could use 4" wheels and still maintain complete control while crossing over and driving on the scoring platform.
Because we lack extensive machining resources we designed this drivetrain to be built using only a drill press and a band saw through extensive usage of VexPro VersaFrame. |
Re: Drive Systems
Here is what we call the HI Drop Drive.
The pneumatic actuated center wheels allow us enough clearance to drive over the bump and will center the robot while driving the length for ease of scoring.. Depending on how you look at it, it is either an "H" or "I", since we are from Hawaii we went with it.. This is an early picture of the system. http://www.chiefdelphi.com/media/img...4205589a_l.jpg More to come as the media team gets it to me.. Good luck to everyone. Aloha! |
Re: Drive Systems
Do those center wheels scrub a lot when you rotate?
Nope look at the pic closer... Air cylinders lift them off the floor. We weren't sure how it would work during competition, but got us to finals last weekend in Waterbury.
#10
Re: Drive Systems
We did Omni H with center suspension (Early pic while figuring suspension..which makes a huge difference took us 4 weeks to figure it out)
https://fbcdn-sphotos-a-a.akamaihd.n...a0e94dd5d6f547 Last edited by Boltman : 06-03-2015 at 20:55. |
#12
Re: Drive Systems
I saw some hexagonal robots last year (mainly vacumn bots for some reason). Those were interesting to say the least. My favourite drive this year so far is 1114's kiwi/crab drive.
#13
Re: Drive Systems
Re: Drive Systems
We've used a 6WD and a 4WD successfully in my time. The year before I joined they made a robot with an 8WD and 8020, which still runs today.
Over the summer we may experiment with swerve drives if we get the necessary manufacturing resources to make a good one. |
#15
Re: Drive Systems
I put together a lesson on drive systems for our (boreal) summer 2014 "robocamp". Trying to classify drives, I came up with something like:
I did not include a monobot, or what I've personally called a "dizzy drive" (crab with a big steerable lazy susan for the "upper robot"). I'm sure there are other possibilities. Last edited by GeeTwo : 08-03-2015 at 23:18. |
