Axis Camera help
Does anyone have any idea why our camera would be working until we configured the bridge to the FMS? We had not had any problem with the Axis camera working for us until after we configured the bridge at the Rock City Regional. Since then, we have been running blind
Re: Axis Camera help
Probably because you set a static IP address that isn't compatible with link-local IPs. See http://wpilib.screenstepslive.com/s/...g-at-the-event. The CSA at your event should be able to help.
If you are trying to get at the axis camera through the SmartDashboard, then try using this this version of the SmartDashboard:
This version of the SmartDashboard adds support for using mDNS to access the axis camera, whereas previously you could only add a static IP. In order for this to work, you need mDNS enabled on the axis camera (see https://decibel.ni.com/content/docs/DOC-41079). If it is some other problem, then check with your local CSA. |
Thank you! We will try these suggestions when we get to the pit this morning.
