Go to Post Reffing a FIRST event is unlike being an ump or a ref at any other event. Where else is a game invented each year and over 1000 teams play this game within 3 months of its birth? - Andy Baker [more]
Unread 07-03-2015, 11:52
Happy Birthday! Jasmine11197 Jasmine11197 is offline
FRC #1946 (Mishka Monsters)
Rookie Year: 2012
Jasmine11197 is an unknown quantity at this point
PLEASE HELP!!!
Hello firends,
the Israeli regional will start in couple days, our team still have problem with the autonuomos , and sadly our mentor has to stay at the hospital with his son
We dont know how to write the code correctly
If anyone can send me any file or examples , it would be really helpful and will be appreciated!
We use C++
Thank you already!
Unread 07-03-2015, 14:03
Sparkyshires Sparkyshires is offline
AKA: Michael Shires
FRC #0384 (Sparky)
Sparkyshires is an unknown quantity at this point
Re: PLEASE HELP!!!
What drivetrain do you use?
Have you checked the screensteps?
How much software do you know?
Just asking for code is a fairly broad topic, if you can supply more information, more people will be able to help you.
"Measure with a micrometer, mark with chalk, cut with an axe."
Unread 07-03-2015, 18:10
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Re: PLEASE HELP!!!
Also, which robot template do you use (sample, iterative, command)?
At a minimum, you should have at least two autonomous routines this year:
  1. drive forward at a speed and for a duration which moves you forward about 3 meters, to participate in a robot set
  2. do nothing, to be used if at least one of your alliance partners cannot participate in a robot set and another has a complex autonomous for which you should just stay out of the way.
You can select which to use either through the driver station or a switch on the robot connected to a DIO port. As Sparkyshires noted, the screensteps are a good place to start.
Even if you have any higher autonomous ambitions, you should still start with these two to figure out how it works with something simple.
Unread 07-03-2015, 19:16
nandeeka's Avatar
nandeeka nandeeka is offline
FRC #1868
Rookie Year: 2013
nandeeka is on a distinguished road
Re: PLEASE HELP!!!
Which sensors do you have/can you put on your robot?
Unread 10-03-2015, 03:17
chloe's Avatar
chloe chloe is offline
human
FRC #1868 (Space Cookies)
Rookie Year: 2013
chloe is an unknown quantity at this point
Re: PLEASE HELP!!!
Have you read WPILib's screensteps live? http://wpilib.screenstepslive.com/s/...g-a-base-class
If your base class is IterativeRobot, you will write your autonomous in
// called when you enter autonomous
// called every loop through your code
If you know how to write teleop code, it is a simple matter to transfer that to autonomous.
For command-based robot, read the guide here: http://wpilib.screenstepslive.com/s/...onomous-period
