Go to Post 3 weeks vacation here...every single day devoted to volunteering for FIRST. Am I crazy? Yes...I am most definately crazy...but crazy has never been this much fun. - Andy Grady [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 07-03-2015, 15:00
adampaskowitz adampaskowitz is offline
FRC #4345
adampaskowitz is an unknown quantity at this point
Changing dimensions of downloaded base
Our base is about 3" wider than the long base, so I've been trying to modify the downloaded bases in Inventor. It seems like if I could lengthen Sheet Metal Front-Back_19 and Churro cross link and Screws_20 by 3" each, everything would be fine. I've tried to Direct Edit them, but that creates a mess. When I resize the parts, the extra material just hangs off the sides. I've looked at the help screens which make it seem like I ought to be able to cut a part in the middle along a plane and then extend it, but the downloaded parts have no faces or individual features I can work with. Is there some way to adjust the dimensions of the base?
Unread 07-03-2015, 19:05
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Re: Changing dimensions of downloaded base
I don't know enough CAD to be of direct help, but some questions for which the answers will help those who can:
  • Are you referring to the AM 14U2? If not, what?
  • From what url did you get your "downloaded base" CAD files?
Unread 07-03-2015, 19:29
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
Here is a link to the same question. There is a sample file located in one of my responses. Direct Edit is the correct work flow.
http://www.chiefdelphi.com/forums/sh...d.php?t=132932
If you are having issues, send me the name of the part file and I will edit the part for you.
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
