Go to Post Using a mouse is so 20th century! - Tom Bottiglieri [more]
Unread 07-03-2015, 18:15
arshacker arshacker is offline
arshacker has a little shameless behaviour in the past
GetString
Not a problem to get a string from "DB/String x " if the string is entered from a keyboard and terminated with a mouse click.
What if, however, the string is generated on the dashboard by say a control whose output is converted to a string and then transfered to the above mentioned DB/String. GetString fails because no mouse click. Any labview pros out there who can help??
Unread 12-03-2015, 20:54
JefferMC JefferMC is offline
AKA: Jeff Corbett
FRC #1319 (Flash)
JefferMC will become famous soon enough
Re: GetString
Why would you ask a question for a LabView pro on a C/C++ forum?
Unread 13-03-2015, 02:58
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Re: GetString
How are you feeding the data from the output of this other code to the DB/String control?
Is there a reason you are using one of the DB/String keys instead of writing directly to a newkey using the SmartDashboard Write VI?
