Go to Post I am specifically looking for Rhode Island, Hawaii, New Hampshire, Nevada, California, Florida, ... oh heck, all of the rest. - Rosiebotboss [more]
Unread 08-03-2015, 17:07
vertigo's Avatar
vertigo vertigo is offline
FRC #4619 (Hawkbots)
Rookie Year: 2013
vertigo is an unknown quantity at this point
AndyMark 9015 Motor (am-0912)
Got a quick question about the AndyMark 9015 Motor (am-0912). We are trying to interface it with a PG27 planetary gearbox (purchased separately). Are the two pieces linked below the only other parts I need to properly interface the motor to the gearbox? Thanks!
http://www.andymark.com/product-p/am-0169.htm
http://www.andymark.com/product-p/am-0040.htm
http://www.team4619.com/
Unread 08-03-2015, 17:40
thinker&planner thinker&planner is offline
AKA: CAAAAAD
Team Role: Mechanical
Rookie Year: 2013
thinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to behold
Re: AndyMark 9015 Motor (am-0912)
Those are for a different series of AM Planetary Gearbox, I believe. In fact, you don't even need the adaptor plate, the PG27 is built to accept the 9015 (among others), no additional hardware needed (except the pinion).
If you want a 9015 motor on a PG27, they sell it here.
We used these on our intake this year, and were very happy.
But before we succeeded, we attempted to pull the pinion gear off of the 775 motor that was installed in our PG27s, and succeeded. But when we pressed it onto the 9015, it split in two pieces. After all, it is "formed from powdered metal."
After a lot of searching, I found this, which is the pinion that you need. It was not under pinion gears, but instead under planetary gears.
Hopefully someone will make this more clear on the AM website; a link to the correct pinion from the PG27 page would be extremely helpful and reduce confusion.
Unread 08-03-2015, 20:42
vertigo's Avatar
Rookie Year: 2013
When comparing the combination motor/gearbox that you linked with a picture of a stand-alone PG27, it still looks like there is an additional silver adapter plate that is added to the back of the gearbox. We currently have both the motor and the gearbox separate and the motor output shaft is too long for them to be mounted together without some additional hardware in between.
It does look like I had the wrong pinion though. Thanks!
Unread 08-03-2015, 20:51
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
I believe you need this adapter plate to interface a 9015 to the gearbox. (It says it is for the PG71, but if I remember correctly, it is the same style mounting for the PG27. You will need to get the 11 tooth pinion for it, though, along with some new mounting hardware. (If you need the hardware, you could order this and just use the 11 tooth pinion instead of the 17 that comes with the kit.)
I'm right 90% of the time, so why worry about the other 3%?
Unread 08-03-2015, 21:08
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
FRC #0461 (Westside Boiler Invasion)
Team Role: Coach
Peyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond repute
It may be easiest to call the folks at AndyMark to ensure you are able to do what you want to do.
461 Westside Boiler Invasion
2016 Tippy Quarter finalist, Warren Finalist, IN State Semi Finalist,B^3 Double Finalist
2015 Indy Semi finalist, Purdue Quarter Finalist, IN State Quarter Finalist, CORI QF, R2OC Finalist, RAGE Winner
2014 Boilermaker Semi finalist, Crossroads Quarter Finalist, & CAGE Quarter Finalist
45 Technokats
2013 Boilermaker Quarter finalist
2012 CAGE Semi finalist & Queen City Champion
2011 CAGE Quarter finalist & Midwest Semi finalist
2010 CAGE Quarter finalist, Boilermaker Champion, & Washington DC Quarter Finalist
Unread 09-03-2015, 01:55
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
The gearbox by itself is $55, the gearbox with a motor attached or gearbox with motor and backshaft attached is $69. Given that you're going to have to install it in the pits at competition, it makes far more sense to me to show up with a COTS part at $14 more than have to swap out gearboxes with motors and maybe press on a new pinion unless you have some really tight budget or R9 issues.
