| Thread Tools |
Rating:
Display Modes |
I no do math, can someone give me a quick math lesson on solving the ranking equation.
Thanks! |
Re: Math: How to solve ranking equation
Do you mean in Qualifications? They just take your average score from each game you played in quals, then rank the teams from highest to lowest.
They average your alliance's score as your Qualification Average and they go in the following order:
Qual Avg Cooperative pts Auto pts RC pts Tote pts sum of Noodle pts Random FMS sorting See 5.3.4 of the Game Manual. |
What ranking equation do you mean? Ranking is simple: more points is better. To a first approximation, a team ranks above other teams with fewer points, and below other teams with more points.
That formula is only relevant for district events. It converts ranking to "District Qualification Points". A comprehensive explanation of the Inverse Error Function belongs in an advanced statistics class. All you need to know is that it is built in to tools like Matlab.
http://www.mrexcel.com/forum/excel-q...ml#post1146833 Code:
Function invERF(y As Double) As Double
Dim pi As Double, x As Double, d As Double
pi = 3.14159265358979
If y < 0 Then
invERF = 0 'interval includes the mean only
Exit Function
ElseIf y >= 1 Then
invERF = 10 'makes the interval include everything
Exit Function
'for my purposes, I only want the function to process input from 0 to 1
ElseIf y < 0.596 Then
x = sqr(pi) / 2 * y * (1 + (pi / 12) * y * y)
Else
x = sqr(-Log((1 - y) * sqr(pi)))
End If
d = (y - ERF(x)) / (2 * Exp(-x * x) / sqr(pi))
x = x + d
Do While Abs(d) >= 0.00000001
x = x + d
Loop
invERF = x
End Function
Function ERF(x As Double) As Double
Dim f As Double, c As Double, pi As Double
Dim j As Integer
c = 0
If 1.5 < x Then
c = 2 - c
j = 3 + Int(32 / x)
f = 0
Do While j <> 0
f = 1 / (f * j + x * sqr(2))
j = j - 1
Loop
f = f * c * (3 - c * c) * Exp(-x * x) / sqr(2 * pi) + (c - 1) * (3 * c * c + c - 8) / 6
Else
j = 3 + Int(9 * x)
f = 1
Do While j <> 0
f = 1 + f * x * x * (0.5 - j) / j / (0.5 + j)
j = j - 1
Loop
f = c + f * x * (2 - 4 * c) / sqr(pi)
End If
ERF = f
End Function
-MM |
#10
Basically the formula is given you just have to plug and chug, some calculators will have an inverse error function ability, if your does you find it use it and plug in the necessary values for the variables, N= number of teams at event, R=your final ranking position and alpha is a constant set by the committee based on averages of event size at 1.07. The lines on each end tell you just to round up to the nearest whole number give it a shot for our first event it would look like this:
invERF[( 33-2x13+2)/(1.07*33)]X(10/(invERF 1/1.07)+12) 13. ....... rounded up to nearest whole integer =14 remember inverse is NOT the same as going to the power of -1 if you don't have a calculator with the function already... if you don't have this function at all on your calculator then it gets much more complicated solving for invERF as its a function itself requiring integrals and such Last edited by who716 : 11-03-2015 at 15:05. |
#11
The inverse of f(x) is g(x), such that g(f(x))=x For example, the inverse of f(x)=x2 is g(x)=sqrt(x), not 1/x2 Code:
octave-3.6.4.exe:10> erfinv(0.33) ans = 0.301332146133706 octave-3.6.4.exe:11> 1/erf(0.33) ans = 2.78335488667249 |
#12
Plus, for Qualifications, if the number of teams is not divisible by six, there are surrogate matches, which are the third match for teams that fill the surrogate role.
More Math! |
#13
When the student is ready, the master appears.
#15
I tried to explain the math behind it without calculus or too much statistics, which makes it easier to read but not nearly as in depth as the official explanation (in my opinion). It's mostly a graphical / algebra based analysis to get at the basics of what district ranking is and how your ranking at an event factors into it. Note: I haven't taken any statistics classes and we're not yet in districts, so I'm not sure if everything I wrote is completely accurate. Please let me know if anything is wrong and I'll try to correct it. Last edited by Rachel Lim : 11-03-2015 at 02:11. Reason: 1. Fixed typo in the text. 2. Fixed typos in the document, replaced link. (I should proofread more carefully...) |
