Go to Post You know you are addicted to FIRST when you have trouble describing it because you realize it truly is way more than just a robotics competetion. - vivek16 [more]
Unread 10-03-2015, 18:47
sanelss sanelss is offline
FRC #1658
sanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to behold
Team 1658 2+ stack practice runs, robot overview
2.5 full stacks: https://www.youtube.com/watch?v=GYDu...ature=youtu.be
2 full stacks with knocked over cans: https://www.youtube.com/watch?v=s7WM...ature=youtu.be
Team 1658 drive system explained : https://www.youtube.com/watch?v=5q1T...ature=youtu.be
Team 1658 robot functionality and design overview: https://www.youtube.com/watch?v=8jd9...ature=youtu.be
Unread 11-03-2015, 20:25
Georges's Avatar
Georges Georges is offline
FRC #5479 (Café Bot)
Team Role: Leadership
Rookie Year: 2012
Georges is an unknown quantity at this point
Smile Re: Team 1658 2+ stack practice runs, robot overview
Saw this robot while we practiced at the Cyborg Cat's field several weeks back.
Glad to see you fixed the issue with the totes falling out! Very impressive machine!
Unread 11-03-2015, 22:55
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
Team Role: Coach
Rookie Year: 2010
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Have you tried dropping two totes before lifting the full stack? It seems like your robot is low enough that you could shave a few seconds off by dropping the first tote in and centering it, then dropping another on top of the first, and then picking up the two. It would keep your human player from waiting while your lift cycles. It might only be a few seconds here and there, but it could be enough to finish that third stack.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 11-03-2015, 23:29
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
FRC Video Review - Change is Coming
FRC #4329 (Lutheran Roboteers)
Team Role: Coach
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
Really solid robot, if you guys can have even half that performance you'll be very strong at St. Louis next week. Good luck!
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 12-03-2015, 07:40
FRC #1658
ye we made several changes which makes it pretty much fool proof scoring now. no more issues with losing a stack! well... unless the driver decelerates too fast, we will lose the can but the stack will still stay inside at least =p
Unread 12-03-2015, 07:44
FRC #1658
We have, if the robot is perfectly aligned to the human station than this works without a hitch, but if it's off the 2nd tote won't properly align itself and since we can't adjust it, there is potential for it to be very unstable making it rather easy to lose the stack. Hence why we avoid doing it.
Our current best run is 2x 6 totes and a third stack of 5 totes. So under ideal conditions and doing this trick we may be should be able to achieve 3 full stacks. But we're not really going for that anyway, we just want to make sure we can get 2 full stacks every run and we should be good.
Unread 12-03-2015, 07:58
FRC #1658
our goal is to go for 2 full stacks(noodle+container+6totes) every round. The partial third stack won't be worth the haste or risk of knocking over the other stacks, we're mostly doing it just to see what the robot can do under theoretical best conditions and may attempt it in finals if it's that close of a game. We are currently able to do this consistently and have about 25-35s remaining after scoring the 2nd stack, even if the 2nd container is knocked over. The only thing that would prevent us from achieving this goal is catastrophic robot failure or major driver error(it would almost have to be intentional on their part). However from all the use and abuse it's been through so far, that doesn't appear to be a concern. I really don't know at this point what would prevent us from being able to perform as we expect, but this is FRC and if there's one thing i've learned over all these years is that things are never as expected and murphy will get you every time!
Team Role: Coach
Rookie Year: 2010
It looks great, definitely wouldn't worry too much about that extra tote or two. I'm just always looking for that way to shave a second off here or there to get more done. Good luck this season!
Andrew Basse
