Go to Post FIRST is all about going past theoretical limits. - Foster [more]
Unread 11-03-2015, 17:19
ShaneWong ShaneWong is offline
ShaneWong is an unknown quantity at this point
Question Configuring the radio for Competition Use
Hi, I was just wondering how we configure our radio for use at the competition. Right now we just have it configured for home use.
Unread 11-03-2015, 17:20
Owen Busler's Avatar
Owen Busler Owen Busler is offline
Build Captain
FRC #0303 (Test Team)
Team Role: Leadership
Rookie Year: 2014
Owen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant future
Re: Configuring the radio for Competition Use
Each event has computers where you bring your d-link to configure it to the events field.
Unread 11-03-2015, 17:22
ATannahill ATannahill is offline
AKA: Alex Tannahill
ATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond repute
There will be a WPA kiosk at your event. It is usually set up on a tough box computer and can vary in location. I would suggest you check inspection first, if it isn't there, the inspectors should know where it is.
You will need to power your radio, put it in bridge mode using the switch on the back (all the way towards the power port) and hook it up by ethernet to the computer. You then type your team number into the computer and click the button on the screen once the DAP-1522 has booted (the power light will be blue when fully booted). The program will take care of it for you.
The radio will no longer be a DHCP server and you will not be able to connect wirelessly.
