Go to Post I should learn to keep my mouth shut until I actually look at the rules. - seanwitte [more]
Unread 13-03-2015, 14:36
SirGibbs SirGibbs is offline
FRC #5676 (Hornets)
Rookie Year: 2015
SirGibbs is an unknown quantity at this point
arcade drive
Hey guys I am from team 5676 and we have a little or big problem with our arcade drive and the java program. We are using talon motor controllers with the kop andymark motors and pneumatic's. But we don't get it running. The robot is just turning around the y and at the x axes at option 1 but the pneumatic's are working. At option 2 is it not driving and the pneumatic's aren't working also but I thought that it would be he exact copy of the example but the code is getting permanently deployed at the roborio. Because an other problem is that at option 1 is the code stopping and getting periodically erased from the roborio at around 1;50 until I restart it. My first thought was that it's maybe running out of ram but that doesn't seem to be the problem.
Every help or input would be highly appreciated. I thank all of you in advance for your time and help.
option 1:
Code:
package org.usfirst.frc.team5676.robot;
import edu.wpi.first.wpilibj.DoubleSolenoid;
import edu.wpi.first.wpilibj.RobotDrive;
    RobotDrive myRobot;
    Joystick stick;
    DoubleSolenoid Piston;
    public void robotInit() {
    	myRobot = new RobotDrive (0, 1, 2, 3);
    	stick = new Joystick(0);
	  myRobot.arcadeDrive(stick);
    	Piston = new DoubleSolenoid (0,1);
    	   		if(stick.getRawButton(5)) {
    	   			Piston.set(DoubleSolenoid.Value.kForward);
    	   			System.out.println("'A' button is pressed: Piston moves forward");
    	   	  else if(stick.getRawButton(6))
    	   			Piston.set(DoubleSolenoid.Value.kReverse);
    	   			System.out.println("'B' button is pressed: Piston moves backward");
    	   		else
    	   			Piston.set(DoubleSolenoid.Value.kOff);
    Piston = new DoubleSolenoid(2,3 );
		if(stick.getRawButton(3)) {
	  else if(stick.getRawButton(4))
		else
Piston = new DoubleSolenoid(4,5 );
	if(stick.getRawButton(1)) {
 else if(stick.getRawButton(2))
	else
		Piston.set(DoubleSolenoid.Value.kOff); }
     * This function is called periodically during test mode
    public void testPeriodic() {
option 2:
Code:
import edu.wpi.first.wpilibj.Timer;
    RobotDrive myRobot;
    Joystick stick;
	  while (isOperatorControl() && isEnabled()) {
            Timer.delay(0.01);
    	   		else
		else
	else
