Go to Post Don't fight bureaucratic morons... embrace them! Humour and publicity will take care of the rest. - dtengineering [more]
Unread 15-03-2015, 09:45
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Rookie Year: 2012
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
Arduino - RoboRIO Question
We've created an Arduino based indicator that we want to use, which gets triggered by the relay signal that is sent to a Spike. (One action is activated when the motor is run in one direction, and a different action is activated when the motor is run the other direction. A third "neutral" action runs when the motor is not engaged.)
Before installing, we measured the voltage of the red and white PWM wire leads (with respect to the black) and found them to be very close to +5v (for each direction the motor is run, respectively).
Using the 5V supply from the Arduino itself to simulate the voltage from the PWM wire signals, the program worked perfectly off the robot.
When we put the indicator on the robot, it remained in the "neutral" third action no matter what we did with the motor. When we checked the voltage again (white and red from PWM WRT black), we found it to be now only approximately 1 volt.
So I guess my questions (finally) are (1) Why does the voltage read 5 Volts when not attached, and only 1 Volt when attached...and (2) Is this normal or have we done something wrong. Then (3) If this is normal, we can use an analog input...what minimum voltage should we expect at each signal pin, so we know what to use as our "trigger" value?
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
