Thread Tools |
Rating:
Display Modes |
Re: Best way to cool CIM motors?
At the moment, I'm thinking that using surgical tubing or bungee cord to take some of the strain off the motors. The other option my team is considering is a bar that locks up under the carriage holding our forklift mechanism while we drive. Thanks for all the great responses! |
If it's possible, disc brakes are really good.
Constant-force springs might last longer than surgical tubing, depdening on stretch. |
Using springs/bungees to offset the weight of everything is the first thing I would recommend. If you have a way to put a brake on the transmission (which might be as easy as a pneumatic piston jamming some rubber between two gears) then your motors will probably remain cool for the whole match. If you do either of those effectively, you can probably even get rid of the second motor. |
As an example: my team is using one CIM motor to drive our elevator. The CIM drives an AndyMark RAW Box (am-2372) with reduction ratio 14.2:1, which drives a second reduction stage made from VexPro gears with ratio 84:30, which drives a 36 tooth 5mm pitch timing pulley, which drives the elevator belt. So, our overall gearing is calculated as follows: At the pulley: 36 teeth/rev x 5 mm/tooth = 180 mm/rev belt speed So our elevator moves 180 / 25.4 / 12 = 0.59 ft per pulley revolution, so to takes 1/0.59 = 1.69 pulley revolutions to raise our elevator one foot. Multiplying this by our gear ratios gives 1.69 x (84/30) x 14.2 = 67.3 motor revolutions to raise our elevator one foot. At full voltage the CIM motor turns at ~5200 rev/min = 87 rev/sec, so the CIM motor could raise our elevator 87/67 = 1.3 ft in one second, if there were no load on it. ---- Using the same method to calculate for the system with a Toughbox and a 42 tooth pulley gives 18.5 motor revolutions to raise the elevator one foot, and a no-load speed of 87/18.5 = 4.7 feet per second. This speed is probably too high, considering gamepiece loads and likely sources of friction, so it is not surprising that the CIM motors are running hot. |
Thanks for the great responses everyone!! Our final solution is a bar that will rotate up and provide a hard stop at the height we will be carrying our stacks at. Hopefully that wil minimise the time we have the motors stalled.
We do not hold our large stacks off of the ground to score them, they are pushed along the ground by the robot. This way, your lift CIMs don't have to run in reverse to hold up the load...let the ground do the work! Perhaps not strategically or mechanically an option for your robot, but just a thought! |
It was mentioned earlier in the thread, but having a worm gearbox driving your elevator is a viable solution. We used the RAW Box from AndyMark this season and we were relatively pleased with it.
The RAW Box is backdrive-resistant, and once you have your motors hooked up to it, it can easily hold the weight of several totes and a can without any power from the motors. The only time we found the elevator would be forced down is when we were carrying 6 totes and a can, but 5 totes and a can was fine. We had the motor controllers (Victor SRXs) in brake mode, and combining that with the natural resistance of the gearbox (which took the brunt of the force), our elevator motors typically ended extended practice sessions at a slightly warm temperature. I think we enjoyed it more because we didn't have to devote more time and resources to a "proper" braking system. |
I'm surprised there are 36 posts and nobody mentioned the CIM Cooler. Check out some of their charts, they will show how much of a difference fans and heat sinks make. They will make a noticeable difference, and your robot safer.
You may want to check with AndyMark, but they may be able to deliver http://www.andymark.com/product-p/am-2865.htm straight to your pit in STL. For the last few years we have been running at least 2x 120mm fans on our drivetrain motors and I do believe they improve the long term quality of the motors. |
