Go to Post Sometimes our greatest failures lay the foundations for our greatest success. - =Martin=Taylor= [more]
Unread 17-03-2015, 21:37
DanG100 DanG100 is offline
DanG!
FRC #2367
Rookie Year: 2013
DanG100 is an unknown quantity at this point
Using a separate thread for driving motors?
After being plagued with issues at CVR, with MotorSafetyHelper timeout exceeded errors, I moved all drivetrain calls to a separate thread.
Has any team successfully, but the robot drive code into another thread, to prevent motor safety helper timeout? Or other tips to prevent from happening.
Unread 17-03-2015, 21:50
JefferMC JefferMC is offline
AKA: Jeff Corbett
FRC #1319 (Flash)
JefferMC will become famous soon enough
Re: Using a separate thread for driving motors?
You could lengthen the timeout from the default of 0.10 seconds to something less touchy... like 0.21 seconds. A lot of teams just disable it altogether; safety is such a pesky thing.
Are you sure you're setting the motor values in every iterative pass?
Are your iterations taking more than 0.02 seconds to execute? Are you having to do a lot of computations (camera processing)?
Are you sending too much data to the dashboard (or too often) and having the communications jam up on you?
Unread 17-03-2015, 22:05
Ben Wolsieffer Ben Wolsieffer is offline
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Rookie Year: 2011
Ben Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud of
I would recommend not moving your drive code to a separate thread, because it is easy to create lots of subtle bugs this way, such as race conditions or deadlocks (less likely in robot code, but still possible).
The motor safety timer (ie. watchdog) also exists for a very good reason. If you run your drive code in a separate thread, and the main robot thread crashes, the robot will not stop like it is supposed to, possibly causing a runaway robot (edit: It will still stop when you press disable, but what I meant was that you might not be able to stop it quickly if the robot stops responding to joystick inputs and you do not realize it immediately).
My recommendation is that you figure out what part of the code is taking a long time to execute (and causing watchdog timeouts), and possibly move that to a separate thread (likely candidate: vision processing). I would look at Jeff's suggestions and try to see if you can find the root of the problem. I would not disable the safety until you have thoroughly examined your code, because the timeouts are likely a symptom of a real problem that could make your controls laggy or unresponsive.
If you do move code to a separate thread, make sure you understand well the concepts of multithreading, because threading bugs can be a huge pain to track down, especially under pressure at a competition.
2016 North Shore District - Semifinalists and Excellence in Engineering Award
2015 Northeastern University District - Semifinalists and Creativity Award
2014 Granite State District - Semifinalists and Innovation in Control Award
2012 Boston Regional - Finalists
Last edited by Ben Wolsieffer : 18-03-2015 at 17:40. Reason: Clarify one of my points
Unread 18-03-2015, 16:59
DanG!
FRC #2367
Rookie Year: 2013
But won't the FMS still disable the drive motors even if motorsafetyhelper is disabled?
Unread 18-03-2015, 17:11
Dartmouth 2020
AKA: lopsided98
Rookie Year: 2011
Yes, assuming you press the e-stop or disable button, but that might not happen immediately when someone realizes the robot is no longer responding to their inputs, especially while practicing. Admittedly, disabling the watchdog is not that big a deal safety wise, but it is more important in discovering that code is causing the robot controls to not run as fast as they should be.
Unread 18-03-2015, 17:28
Jefferson Jefferson is offline
AKA: Jeff Clements
FRC #0016 (Bomb Squad)
Rookie Year: 2010
Jefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant future
Originally Posted by lopsided98 View Post
If you run your drive code in a separate thread, and the main robot thread crashes, the robot will not stop like it is supposed to, possibly causing a runaway robot.
Do you know this for a fact or just theorizing here? If the main robot thread actually crashes, the HAL + FRC firmware disable all outputs, right?
I'm not deeply familiar with these concepts. Maybe somebody could comment with a little more authority than I.
Unread 18-03-2015, 17:37
Dartmouth 2020
AKA: lopsided98
Rookie Year: 2011
Sorry for the misunderstanding: I meant that it will run away until you realize what is happening and press disable/e-stop, which isn't that big a problem.
Unread 18-03-2015, 18:02
AKA: Jeff Clements
Rookie Year: 2010
But I still don't think that's the case. I don't believe separate threads outside the main robot thread can keep the robot alive if the main thread has died.
Unread 18-03-2015, 18:13
Dartmouth 2020
AKA: lopsided98
Rookie Year: 2011
Yes, your right. I'm more used to working with Java, where this is not the case, but in C++ (which I just realized the OP was using), exiting the main thread does cause all other threads to terminate.
Unread 18-03-2015, 18:25
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Yes, your [sic] right... in C++, exiting the main thread does cause all other threads to terminate.
Jefferson wrote "if the main thread has died", and lopsided98 wrote "exiting the main thread".
So it's not yet clear if you are both saying exactly the same thing. It depends on Jefferson's intended meaning of "died": If the main thread is blocked or busy-waiting for an event that never occurs, it could be considered to have "died" but not "exited".
Unread 18-03-2015, 18:33
Dartmouth 2020
AKA: lopsided98
Rookie Year: 2011
Ether brings up a good point. I was thinking about the case where the main thread finished its execution or threw an exception, in which case all other threads would exit.
But if for the main thread locked up without actually exiting or crashing (something that becomes more likely when you start communicating between multiple threads), the other threads (such as the one controlling the driving) could continue executing. Like I mentioned before, the e-stop/disable buttons would still be able to stop the robot in this case.
Unread 18-03-2015, 19:51
connor.worley's Avatar
connor.worley connor.worley is offline
FRC #0973 (Greybots)
Rookie Year: 2010
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
OP, would you mind posting your code? I would advise trying to find the root of the problem in the main thread rather than moving drive code out.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 18-03-2015, 19:57
Ether's Avatar
Rookie Year: 1969
ditto that.
Unread 19-03-2015, 02:21
AKA: Jeff Clements
Rookie Year: 2010
Good point. I meant exiting the main thread.
I'll throw in with everybody else and recommend finding the root cause of the motor safety errors in the first place.
  #15   Spotlight this post!
Unread 19-03-2015, 11:59
DanG!
FRC #2367
Rookie Year: 2013
This is the code for the robot, except all the camera code was commented out at competition.
https://github.com/Saint-Francis-Rob...367/FinalRobot
