Go to Post "Ugly can win" - Mr. Lim [more]
Unread 17-03-2015, 22:36
Techwiz's Avatar
Techwiz Techwiz is offline
Blake B
AKA: Blake
FRC #4909 (The Bionics)
Rookie Year: 2007
Techwiz will become famous soon enough
Trouble with serial port: HAL - VISA: Resource Not Found
Greetings, we hare having trouble using our NavX MXP via its USB connection.
We have our NavX connected using a USB cable as described:
https://code.google.com/p/navxmxp/wi..._via_USB_cable
When running the sample code https://code.google.com/p/navxmxp/so...eRobotExample/
We get the following exception:
Code:
ERROR Unhandled exception: java.lang.NullPointerException at [
org.usfirst.frc.team2465.robot.Robot.operatorControl(Robot.java:93),
edu.wpi.first.wpilibj.SampleRobot.startCompetition(SampleRobot.java:148),
edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:234)]
The error appears to be referring to the first use of the imu object.
Code:
boolean is_calibrating = imu.isCalibrating();
Further investigation reveals that the SerialPort may be the culprit.
We moved the following line of code into the robotInit method yields a more descriptive error:
(Robot.java:81)
Code:
SerialPort my_serial_port = new SerialPort(57600,SerialPort.Port.kUSB);
Code:
ERROR Unhandled exception: java.lang.RuntimeException:  Code: -1073807343. HAL - VISA: Resource Not Found at [
edu.wpi.first.wpilibj.hal.HALUtil.checkStatus(HALUtil.java:48),
edu.wpi.first.wpilibj.SerialPort.<init>(SerialPort.java:198),
edu.wpi.first.wpilibj.SerialPort.<init>(SerialPort.java:251),
org.usfirst.frc.team2465.robot.Robot.robotInit(Robot.java:81),
edu.wpi.first.wpilibj.SampleRobot.startCompetition(SampleRobot.java:121),
Any Ideas?
Blake
Electrical, Programming and Design
Creator FRC Q&A 2017
Mass FRC Team 4909: The Bionics
Maine FRC Team 5122: The RobOTies (2014-2015)
Maine FRC Team 2648: Infinite Loop (2008-2011)
