Go to Post Everyone builds their robots uniquely, runs their teams differently, and prefers all kinds of flavors of ice cream. Now, we are seeing that folks vent and react differently to a frustrating situation. ... and that's ok. - Andy Baker [more]
Unread 19-03-2015, 08:22
MrRiedemanJACC MrRiedemanJACC is offline
FRC #2611 (Jacktown Vectors)
Rookie Year: 2011
MrRiedemanJACC will become famous soon enough
3-D Printing with Metal
I teach Project Lead the Way at the Jackson Area Career Center and we are now in the Engineering Design and Development class. For those of you not aware of this class it is the capstone project for my students. I have one team that is working on developing an affordable metal 3-D printer. They are at the point in the project where they are looking for customer data to help drive the design. If you could, please take a few moments to take the attached survey and leave comments also. Thank you soo much for your time.
https://docs.google.com/forms/d/1_j-...?usp=send_form
John Riedeman
IED, POE, DE, and EDD PLTW Instructor at the Jackson Area Career Center
Team 2611 Jacktown Vectors Mentor
Unread 19-03-2015, 09:33
techhelpbb's Avatar
techhelpbb techhelpbb is offline
FRC #0011 (MORT - Team 11)
Rookie Year: 1997
techhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond repute
Re: 3-D Printing with Metal
There are some typos in the survey: write not wright.
Also is this a laser sintering printer design?
Unread 19-03-2015, 09:59
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
Team Role: Coach
Rookie Year: 2010
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
How do they plan to extrude metal? Especially iron or ferrous metals? Even aluminum would take an impressive heating element and then would result in a puddle of metal rather than a controlled plastic flow of material.
Or is the plan just to deposit controlled amounts of material in a small area and build up layer thickness based on the thickness of metal flake? Essentially making a thin layer metal laminate? I'm curious as to their solution for this, and am interested in how you are testing results.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 19-03-2015, 11:34
Sperkowsky's Avatar
Sperkowsky Sperkowsky is online now
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Team Role: Leadership
Rookie Year: 2014
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
I believe all metal 3d printers use a mix of plastic and metal in them. I also know some do metal coated items. Ill see a bit more of the trend in a little over a month at the 3d printing expo.
Unread 19-03-2015, 11:46
Chris_Ely's Avatar
Chris_Ely Chris_Ely is online now
AKA: luckof13
FRC #3414 (HackBots)
Rookie Year: 2010
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
John,
This might be of interest to your students as they continue their design:
Scientists Build a Low-Cost, Open-Source 3D Metal Printer
I submitted the survey. I am very interested in what your students come up with.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 19-03-2015, 12:01
techhelpbb's Avatar
Rookie Year: 1997
3D printing (really material addition) with a MIG/GMAW welder is not actually a new idea.
The issue with those welders is the spatter and properly slicing the model to insure the welds laid down are consistent over the travels.
You can't really do like a 3D plastic extruder does. A 3D plastic extruder is basically pushing into a state of partial stall on the extruder stepper. That's part of the reason the extruder steppers tend to get hot. Once we get an arc going the spool in a MIG does not take much effort to push too much and takes some skill not to push too little.
So while I can see putting a MIG torch suitable for CNC operation on a Prusa I3 frame in the same way I can so doing it with a CNC plasma cutter. What I don't see is how you control the quality of the weld consistently over different objects. With a plasma cutter the goal is really to cut and sever so as long as you are in the ball park it's good enough considering what it's doing.
To put this in perspective we've had robotic arms do MIG/GMAW for decades now.
There's a process to dial them in to achieve the right results on a consistent flow of similar parts that start at room temperature.
In trying that with 3D printing you are laying down metal that will cool and the size and shape of the target will change as you reheat the welds changing various aspects as the thermal mass changes.
http://hackaday.com/2014/11/07/print...-a-mig-welder/
So in the video they make a simple 'wall'.
Didn't really need a Prusa printer frame for this purpose.
A cheap school robotic arm could manage the same with basic motion control it just wouldn't be Cartesian.
So maybe you start the travel and you exit after the straight line to let it cool or force air to cool it.
However if you look the layers are more inconsistent than 3D plastic printing.
So the 'slicing' or making of layers would become much more difficult for complex layer travels.
I wouldn't aspire to making plates of metal as a 3D printing goal.
At that point I'd rather have a robotic arm welder to weld properly prepared plates for more consistent results.
Maybe more robotic arms to grasp the assembly in progress of assembly.
The inverse kinematics of the robot arm welder and work holders are equally an interesting motion control problem.
That's a problem where the feedback of actually maneuvering the arms manually could be really helpful in training the robot.
Unread 20-03-2015, 01:21
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Best of luck! I would like to see something that's not a welder, as my school banned us from having one on the grounds that it was "unsafe".
Meanwhile, the milling machine, bandsaw, and various power tools are A-OK.
Unread 20-03-2015, 08:32
BeardyMentor BeardyMentor is offline
Just the right amount of Crazy
AKA: Matt Hagan
FRC #1257 (Parallel Universe)
Rookie Year: 2010
BeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud of
Incorrect, There are a few types commonly used. The most common is Direct Metal Laser Sintering. This uses a laser to melt metal powder, then spreads a new layer of powder and so on. Next there is Electron Beam Melting. This preheats a metal powder bed to near the melting point then uses an electron beam to melt the powder. Next is the ExOne process that uses a binder to glue metal powder together, then the parts are infused with bronze in a furnace. There are also selective deposition printers using lasers or electric arcs to melt metal as it is deposited in a similar way to the desktop printers you are likely familiar with. There are also printers that extrude a metal clay. There are some others but this covers 99% of what is out there right now.
When you go to the 3D printing Expo, check out EOS, they usually have an M280 on display. Also Arcam and Renishaw are usually there with some of their printed products.
Unread 20-03-2015, 08:53
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Welding requires proper ventilation as the aluminum additives heat and off-gas. I don't know your shop, but welding is considered unsafe without the ventilation.
In other news, metal 3D printing is so last year:
http://arstechnica.com/science/2015/...tead-of-hours/
